Author Topic: ‘78 750 carburetor missing key part HELP!,,,  (Read 1834 times)
Offline DPO
« on: August 10, 2020, 02:06:57 PM »
After restoring old bikes for 10+ years, I somehow have misplaced a key part to one of the carburetors while rebuilding. It’s not a tiny part, but a part that slides onto the slide rail that provides a way to adjust the height of the slide. I have removed EVERY ITEM in my garage searching for this adjuster arm , and folks, it just ain’t here. Frustration has set in, and now I think that the only recourse I have is to post a photo of the carb bank, as well as the carb that’s missing this part. Please forgive me, as I’m not very talented when it comes to these I-pads and how to pos pics, but here goes!   Oh, and thanks in advance for any help or suggestions.  Everywhere I look here on the inter web says the parts is “no longer available”.
« Last Edit: August 10, 2020, 02:08:57 PM by Brada92 »
If you highside, let it go....If it comes back, it was meant to be!
Offline Remcod
Re: ‘78 750 carburetor missing key part HELP!,,,
« Reply #1 on: August 10, 2020, 02:36:43 PM »
Isn’t it supposed to be like that? One carb being the master for syncing?
Or is this an older picture? Please circle what you are missing. I probably have it but am in Europe so might want to try our American friends first
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: August 10, 2020, 02:49:07 PM »
+1 to Remcod, I have a spare set of those carbs and will have a look if you want?
Offline DPO
« Reply #3 on: August 10, 2020, 02:59:53 PM »
DANG! I believe you may be right!  Thanks a BILLION!
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #4 on: August 10, 2020, 03:13:02 PM »
The #2 carb is typically the "static" carb, but I don't know if it really matters which one is used for the baseline adjustment. Also, I don't see your choke linkage spring connected between the #2 and #3 carbs either. I describe this choke linkage spring here:
http://forums.sohc4.net/index.php/topic,100352.msg1669248.html#msg1669248
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline DPO
« Reply #5 on: August 12, 2020, 04:44:28 AM »
Spent ALL DAY re-assembling these carbs. Had it not been for the links provided here, wouldn’t have happened. As it stands, everything appears to be functioning properly with the exception of the 4 choke plates binding once the cross bar is attached, along with the back plate.  Choke plates will not operate with these two parts installed and tightened.  I have half a day to work on them today...very difficult for me.
« Reply #6 on: August 12, 2020, 05:31:11 AM »
Common problem, especially since the 3/4 choke plates are spring driven from the 1/2 choke rod (i.e. no direct solid link). With the 3/4 choke plates in the closed position loosen the two screws and allow the plate to "align" with the carb body and retighten. Might take a couple of tries, but it can be done. You're almost there!
TAMTF...
Wilbur
Projects:
