Support the site. Your contributions keep this site running.
NO YOU CAN NOT RE USE CIRCLIPS thats for a start, check carefully the guide on the bent valve, any cracking means its duff. No sealant anywhere.Check the restrictors in the base gasket dowels and make sur they go in the correct way up the before fitting cam cover but with cam and sprocket fitted turn engine over a lot to make sure oil gets to the cam
I use locktite on all internal bolts?John
Piston circlips are still available from Honda. Partzilla lists them at $0.88, but I bet you could call your local Honda dealer and give them the part number and get it cheaper than what it would cost to include shipping via Partzilla.
Any negative effects if I leave some parts submerged in acetone for a few days?Sent from my SM-N950U1 using Tapatalk
Quote from: Maraakate on August 11, 2020, 08:55:06 pmPiston circlips are still available from Honda. Partzilla lists them at $0.88, but I bet you could call your local Honda dealer and give them the part number and get it cheaper than what it would cost to include shipping via Partzilla.I've never really been inside a dealership to be honest. I'll have to call but I doubt they'll be more expensive than shipping costs.
