Author Topic: Rear Wheel Conundrum  (Read 1220 times)
Offline DPO
« on: August 12, 2020, 04:52:30 AM »
 So I removed the rear wheel on my ‘78 K,  now can’t figure out where all these spacers go. I re-assembled everything the way I thought it came apart, but the spacers provided will not fit between the wheel and the swing arm. Looked at the picture in my Clymer manual and BikeBandit, neither one was any help. The clymer shows for a “F” model, and BikeBandit is even worse. I can’t see all 3 of these spacers fitting between the swing arm axle provision....Sux getting old!!!
If you highside, let it go....If it comes back, it was meant to be!
Offline Alan F.
Re: Rear Wheel Conundrum
« Reply #1 on: August 12, 2020, 06:00:54 AM »
3 spacers? My K8 only had 2 spacers.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: August 12, 2020, 06:03:11 AM »
There should be a stepped space behind the sprocket carrier between the sprocket carrier bearing and the hub bearing.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #3 on: August 12, 2020, 06:29:52 AM »
Have you confirmed you have the proper parts using the fiche?
https://www.partzilla.com/catalog/honda/motorcycle/1978/cb750k-a-750-four-k/rear-wheel
« Reply #4 on: August 12, 2020, 10:41:44 AM »
Yes 3 spacers , 1 inside sprocket carrier.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #5 on: August 12, 2020, 10:42:10 AM »
Pictures help a lot in this situation. Show us how you have it set up. Do you have the brake plate fully seated?
« Reply #6 on: August 12, 2020, 10:43:58 AM »
Outer sprocket side one should set inside the seal and stay there... are you trying to add an extra ?
Offline Johnie
« Reply #7 on: August 12, 2020, 11:47:17 AM »
Before you do more work on the bike remember to take pics before you disassemble something. No kidding...it really comes in handy. I have looked back a few times during builds. Good luck with it.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Alan F.
« Reply #8 on: August 12, 2020, 11:56:47 AM »
Oh right, gotcha Frank.
I still haven't gotten to replacing those bearings and spokes but I'll remember to make some measured drawings of the hub center spacers when I finally get in there.
I need more lockdown time to work on bikes!
« Reply #9 on: August 12, 2020, 12:20:37 PM »
No big deal , just thought if info is saved, then it's easy to make one if needed.,
Offline Laids
« Reply #10 on: August 12, 2020, 01:58:55 PM »
I recently changed motors in a 78 frame from a 71 to a 78. When I realigned the wheel I only had a group of washers and spacers to use not knowing what was original. After a few tries using a string to check for alignment I arrived at what is in the pics.
« Reply #11 on: August 12, 2020, 02:33:17 PM »
If you have a 78 motor in that , your rear sprocket may have to move out a bit.
Offline Laids
« Reply #12 on: August 12, 2020, 02:45:32 PM »
It,s now a 78 frame with a 78 motor. When I had the 71 motor in it there was spacers and washers to make it line up. When I put the 78 motor in recently I had a bunch of different spacers and washers to work with, but I was able to line up the rear and front sprockets. As the poster said though the parts fiche's don't seem to give the enough details. I know the washers on mine aren't OEM but it's what I had and it works.
Offline DPO
« Reply #13 on: August 13, 2020, 05:38:02 PM »
Got it! Thanks Guys!!!
