Author Topic: CB 750A BOTTOM END SPLIT  (Read 1244 times)
Offline Bazzer
« on: August 14, 2020, 04:37:22 pm »
I need to split the crankcase on my 78 hondamatic, does anybody have any helpful advise ?
Offline bear
  • Leeton in Australia
Re: CB 750A BOTTOM END SPLIT
« Reply #1 on: August 14, 2020, 06:39:47 pm »
What do you need to do once you've split the cases?
Brian
« Last Edit: August 14, 2020, 06:41:18 pm by bear »
Offline Bazzer
« Reply #2 on: August 15, 2020, 01:45:28 am »
I need to look for a small piece of broken piston ring that was dropped in there. i have fished around for hours  with a telescopic magnet, all to no avail. I suppose what i need to know is what do i need to remove before i can split the bottom end. the head, barrels, and pistons are already removed. If there is anyone out there who has done this please share with me what you did.
 Panic over, i have now got it sorted.
« Last Edit: August 17, 2020, 02:38:52 pm by Bazzer »
Offline bear
« Reply #3 on: August 17, 2020, 06:12:30 pm »
Well done.
« Reply #4 on: August 21, 2020, 07:45:02 am »
Splitting/joining the cases is super easy because there are no shift forks.
Offline Remcod
« Reply #5 on: August 21, 2020, 10:53:50 am »
Glad to know. Need to replace leaking outgoing shaft oil seal.
