Author Topic: What is the speedo driver called?  (Read 757 times)
Offline y2kc0wb0y
  • B00msh0cka
  • Shoot the pickle....
« on: August 24, 2020, 09:25:00 AM »
Cannot seem to find what this is speedometer driver part that rides on the front hub body is called?
Don't seem to be able to identify it on exploded views either? Is this part listed somewhere?
BTW How does it come out? I'm trying to convert to some period mags and this maybe needed so I'm trying to get more details on it so I don't booger it up. threads? pressed?
« Last Edit: August 24, 2020, 11:00:12 AM by y2kc0wb0y »
CB750K3 890cc| 2004 VFR800A| 76 CB550F| 77 CB750F| 73 CB350G| 79 XLH| 2007 BMW R1200GS| CB750K2
Offline Maraakate
Re: What is the speedo driver called?
« Reply #1 on: August 24, 2020, 09:48:32 AM »
Speedo or Gear Box Retainer?
1977 CB550K
1979 CM400A
Offline y2kc0wb0y
  • B00msh0cka
« Reply #2 on: August 24, 2020, 11:00:51 AM »
hmm...maybe it is called something else as I don't see it by that name.
« Reply #3 on: August 24, 2020, 11:12:18 AM »
The part you showed does not come out. There is a steel flange and bushing , that fits between this and the Speedo drive..
Offline y2kc0wb0y
  • B00msh0cka
« Reply #4 on: August 24, 2020, 08:00:55 PM »
Thanks for the info Frank.
These PVM wheels do not share the stock configuration but have adaptor to get speedo drive working. (I think I have it mostly correct.) The complication is the other side where the 4 pin threaded seal would go ... I'm wondering out loud how to protect the bearing and how to tighten the axle without pinning the bearing against itself.
« Reply #5 on: August 24, 2020, 09:17:16 PM »
The inner race of the bearing must be tight against something..., both sides.. inner must have spacer between bearings.,
 There are several ways to lock the steel drive plate to the hub to drive the Speedo drive.,
 Hard to see what is going on without a pic of that area.
« Reply #6 on: August 24, 2020, 09:20:38 PM »
 I cut down a stock drive plate so it sat flat and pinned it to my Lester with two roll pins.
« Reply #7 on: August 24, 2020, 09:45:02 PM »
The speedo "drive plate" needs to be against the wheel hub surface, not on top of the rotor hub. The thin chrome cover is not used with a dual brake mod. You can cut down the plate so it fits through the hub of the rotor and pin it to the wheel hub like Don, or cut down the plate, leaving the tabs, and machine recesses into the back side of the rotor hub, essentially replacing the chrome cover.
