Author Topic: new LED head light  (Read 1828 times)
Offline Randy Nevrotski
  • Randy
  • ITS AUTO-MAD-TIC
new LED head light
« on: August 25, 2020, 08:25:04 PM »
put LED headlight in 2 weeks ago . sat night it turned off high beam also . i checked it out No power to Main fuse . didnt check anything yet. should i check key switch or ?  i road 10 miles home it started right up tonight , good power.
1976 CB750A & Other bikes 1980 KZ 650 cafe racer  81 CM400A 82 GS450 79 KZ650 84 NIGHTHAWK 700 77 KZ650 CAFE  87 ZX750R NINJA 2001 KATANA 600 1983 GPz 750 1980 CB750 CUSTOM Past bikes 1974 suzuki GT750 TRIPLE Care Free Custom chopper 117 motor 95 Honda XR650L Dual Sport 87 ZX600R NINJA Honda CB550FOUR 87 Yamaha 225 trike honda 250R trike RM80 HONDA TRAIL CT70
Re: new LED head light
« Reply #1 on: August 26, 2020, 02:19:36 AM »
I need a translator, as it is unclear what the problem is.
I have read what you wrote a couple times and I don't understand what your issue is, nor what you are asking.
  • Randy
  • ITS AUTO-MAD-TIC
« Reply #2 on: August 26, 2020, 08:10:09 PM »
was half asleep . no power to headlight plug and main fuse . its charging 14. v I checked key switch , regulator    im going to take gas tank off tomorrow to check all wires.      can i put a jumper wire to fuse to see if i get power to head light plug
« Reply #3 on: August 27, 2020, 07:07:40 AM »
If you are not seeing power to the main fuse then start Trac Ng the power from battery to the ignition switch and fuse box.
It would be helpful if you were a little more descriptive. Following your logic has some leaps.
What is the voltage measurement of the red wire and black wire to ground at key switch. Are you certain the main fuse is good. Pulling it and testing it or checking voltage on both sides of the fuse.
Is voltage reaching the headlamp plug?
Have you reached the wiring from fuse box to the headlamp?
Which fuse on your bike controls the headlamp? What is your year and model bike? Posting this on your signature as part of your signature automatically helps others when you have questions.
  • Randy
  • ITS AUTO-MAD-TIC
« Reply #4 on: August 29, 2020, 09:07:52 PM »
found problem . fuse box label wrong . it was the starter button . riding down the shore N.J. about 100 miles each way
  • Randy
  • ITS AUTO-MAD-TIC
« Reply #5 on: August 29, 2020, 09:14:02 PM »
starter button wasn't coming out all the way to make contack to turn light on. i pulled it out then light came on. that's after tank was off. i needed to clean it out anyway.
  • Randy
  • ITS AUTO-MAD-TIC
« Reply #6 on: August 30, 2020, 05:50:11 PM »
down and back 200 miles . had 2x harleys brake down had to fix would leave when he said was getting it towed.
« Reply #7 on: September 02, 2020, 11:47:34 PM »
 Those switches are failure prone at this age. You can buy a new right control or find the plastic cage that the switch fits in. Someone was 3D printing them.  ebay maybe?
