Author Topic: Rear axle, SuperSport  (Read 800 times)
« on: August 27, 2020, 05:00:42 AM »
I use on Red rear axle from SuperSport.  That axle, unlike older Ks with hole in the axle head, is 22mm.  Meaning, I can't get the wheel off unless I carry 22mm wrench in my kit.  Anybody dealt with it?    Solution?  Except adding big, honking wrench to the tool pack?
Re: Rear axle, SuperSport
« Reply #1 on: August 27, 2020, 06:06:31 AM »
I use stock Honda wrench on the nut end, early style axle. I never have to hold the opposite end.. that has no nut..
But even if you did need it just make a 5 inch long wrench that fits in tool tray.
 The stock one with add on sleeve , gives quite a lot of leverage..
« Reply #2 on: August 27, 2020, 06:20:49 AM »
The problem was, the axle was turning and I had to hold it to get the nut off.  The old style axle was fitted for a screwdriver, smarter IMHO.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #4 on: August 27, 2020, 09:21:01 AM »
Thanks, Wilbur.
