Author Topic: '77 CB400F fuel fill "door" noise  (Read 1280 times)
Offline mattsz
« on: September 04, 2020, 12:46:11 PM »
Anyone cursed with the hideous hinged fuel tank fill cover - like on my '77 CB400F and possibly other models... I've just got my bike up and running, and the door vibrates at certain RPMs and makes a god-awful racket!  Nothing looks bent or out of shape, but the door contacts the tank along its right side and stands proud on its left.
Anyone have any hints for quieting it down?  Some kind of gasket-like padding, or perhaps an attachment trick?
Offline Bodi
Re: '77 CB400F fuel fill "door" noise
« Reply #1 on: September 04, 2020, 03:42:25 PM »
It should have a rubber ring that wraps around, locks into the metal flange with a groove.
Offline mattsz
« Reply #2 on: September 04, 2020, 05:33:02 PM »
Damn, look at that, you're right!  I have a "multi" parts book which shows it - they call it "packing."  Yet another unobtainium part...  :(
I wonder what kind of U-cross-sectioned rubber or material I could use instead...
Offline Bodi
« Reply #3 on: September 05, 2020, 06:00:11 AM »
If you find something that works, let me know. Mine is disintegrating.
Offline mattsz
« Reply #4 on: September 05, 2020, 06:08:02 AM »
I will.  I know there's some sort of strip that sometimes finds its way onto the lower "pinch-welds" of fuel tanks, but I think those are usually hard "chrome" plastic?
I do have some thin, tape-like adhesive-backed neoprene, which I suppose I could cut into a narrow strip and apply it, folded over, around the perimeter of the door.  But it's much softer and not nearly as sturdy as rubber, no idea how well it would work or how long it would last, especially if it gets wet or exposed to sunlight long-term...
Offline robvangulik
  • Honda Fourever
« Reply #5 on: September 05, 2020, 08:31:46 AM »
Fuel line, slit lengthwise?
Offline mattsz
« Reply #6 on: September 05, 2020, 09:08:43 AM »
Good idea!  Or some similar tubing - it would have to be a pretty small diameter...
« Reply #7 on: September 05, 2020, 11:16:06 PM »
Vac advance pipe on a car?
Offline mattsz
« Reply #8 on: September 06, 2020, 03:06:41 AM »
Black tubing:
Viton, 1mm ID, 3mm OD, from Australia - not cheap:
https://www.ebay.com/itm/Viton-Rubber-Tubing-Tube-Hose-Tubing-Tube-ID-from-1mm-to-16mm/151911299977?hash=item235e9e7b89:g:BfsAAOSwNphWaSgL
Silicone, 0.5mm ID, 1mm OD
             1.0mm ID, 2mm OD
             1.5mm ID, 2.5mm OD
from a modeler's supplier in the UK - not too expensive.  Difficult to attach?
https://www.ebay.com/itm/Miniature-Silicone-Fuel-Line-Tube-1mm-2mm-2-5mm-1-12-Tamiya-1-8-Pocher-1m/141951682927?hash=item210cfac96f:g:JukAAOSw-RRXBY34
