Author Topic: Where do I start?  (Read 3043 times)
nitro7476
Where do I start?
« on: June 10, 2005, 06:20:58 PM »
I just bought 5 750's - 1 '71, 2 '73's, 1 '76 F and 1 '78 k.  One of the '73's is the closest to running.  New battery, and cleaned carbs, I pulled the # 1 plug to see if I had spark, and nothing.  So, my question is where do I look first?  coils? points? or something else?  Please help!
Thanks,
nitro7476
Offline Lumbee
    • My pics...
Re: Where do I start?
« Reply #1 on: June 10, 2005, 06:44:58 PM »
...dag!! 5 bikes?  U jumped in feet first didn't ya?  If no spark, I would first make sure the plugs are good...are the plugs new?  If not spring for a new set.  Next I'd go to ponints...make sure they are are clean, when u turn the ignigion on are th lights on?  Open and close the points with a screw driver, when u do, you should see a spark.
"I'm not a welder, but I play one on HondaChopper.com"
nitro7476
« Reply #2 on: June 10, 2005, 06:53:46 PM »
Yeah, all 5 in one deal on eBay.  no lights when key is on. just got the battery charged and put it in.  will get new plugs, but is there any one thing that would stop all electricity?
Thanks,
nitro7476
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: June 10, 2005, 07:06:07 PM »
Fuse?
nitro7476
« Reply #4 on: June 10, 2005, 07:11:09 PM »
didn't find any
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #5 on: June 10, 2005, 07:36:32 PM »
As in no fuse holder at all?
nitro7476
« Reply #6 on: June 10, 2005, 07:58:10 PM »
exactly.  The other '73 has one with 3 fuses in it.  This one has no fuse box at all.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #7 on: June 10, 2005, 08:20:47 PM »
Well, maybe a bad ground, or without the protection of any fuses, maybe something has gotten fried.
Offline Lumbee
    • My pics...
« Reply #8 on: June 10, 2005, 08:26:13 PM »
...you should have fuses in it...are u say'n theres not even a place to put fuses in it?
rob
« Reply #9 on: June 10, 2005, 08:46:51 PM »
I think I saw that ebay auction.  However, I am excpecting 5 pics...
Rob
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #10 on: June 10, 2005, 08:57:01 PM »
Take the fuse box off of the other `73 and hook it up.
Red striped = headlight
red = main
orange = taillight
If the red main was just hooked up without a fuse you might have toasted wires.
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
nitro7476
« Reply #11 on: June 13, 2005, 07:28:10 PM »
Update:
I got fire!!!  My son happened to walk in front of the bike when I was turning the key, and he noticed that the headlight came on for a second.  Seems I was looking for it at the second position from "off" and it has power at the first position.  I got it to burn some carb cleaner sprayed into the carbs, but the petcock is gunked up with old gas so more cleaning tomorrow when its light again.  I did put the fuse panel on it, but I know I got some wires crossed cause the only fuse in it is the main one, none in the headlight or taillight slot but they both work??!!?  I know I got the main running through the fuse, and I also know I don't have the other 2 wired right.  It felt SOOOO good to hear the 4 into 4's bark some life!!  I will keep you posted on my progress, and try to get some pics, too.  Any suggestions would also be greatly appreciated.
nitro7476
nitro7476
« Reply #12 on: June 14, 2005, 05:23:40 PM »
Got it to run around the yard in first gear!  It wouldn't do second though.  running a little rough, especially when I give it gas too fast.  Nice and easy on the throttle, and it will tach up to about 5k.  Any suggestions what to do next?
Thanks in advance,
nitro7476
Offline Lumbee
    • My pics...
« Reply #13 on: June 14, 2005, 06:50:00 PM »
...congrats Nitro...hearing them purr a little bit is always good positive reinforcment...keeps u go'n!  Have you cleaned the carbs...I mean like pulled them apart and given them a good clean'n?  That should prob be u'r next step...
nitro7476
« Reply #14 on: June 14, 2005, 07:23:33 PM »
Yup, had to. the slides were stuck, and the bowls were full of varnish.  I think it just needs to be run.  The more I have run it, the bettere it got....I like that in a bike   ;D
nitro7476
