Author Topic: Carb slides sticking after rejetting  (Read 1210 times)
Offline Ms Tokyo
« on: September 10, 2020, 05:18:58 PM »
CB550k. Just rejetted and now the slides are sticking. I have the carb bank off and still have a tight spot sliding from WOT to closed. I was thinking my cable or spring was bad but not the case. I did set the air mix screws back to factory settings but can’t believe this is the culprit. I do have to open the bowls and reset float height so I may find something there. Any other ideas?
Offline Kevnz
Re: Carb slides sticking after rejetting
« Reply #1 on: September 10, 2020, 06:25:59 PM »
All slides binding simultaneously? Something amiss in the linkage. Might be just one slide binding, probably a bit of grit in there.
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
