Author Topic: CR29 CARB SETUP  (Read 1405 times)
Offline guamjake
CR29 CARB SETUP
« on: September 16, 2020, 06:47:23 AM »
Trying to setup Cr Carbs, each carb body has a connection on it for a fuel line and then between each carb there is a t connector all but the center t connector is capped. Do I run the fuel line to the center connector or to each carb body ?
Thanks in advance!
Offline guamjake
Re: CR29 CARB SETUP
« Reply #1 on: September 19, 2020, 03:50:14 PM »
answer is T-connector on rail. the connections on each carb body are air vents for the choke circuit. Dont connect fuel lines to them!
