Author Topic: Oil Leak Troubleshooting  (Read 615 times)
Offline BrickWoll
« on: September 19, 2020, 10:16:38 AM »
Hey all,
Finally got the bike together and had a dream 15 minute ride before it bogged down and died.  Looking down, my right shoe and lower leg were splattered with oil.  At that point, it wouldn't start and I could feel no compression in the kickstarter.  After about 5 min, I tried again and it started but required full choke.  Ran again for about 10 min, but would die immediately at idle.  Repeated that pattern a few times to hobble home.
Oil was collecting and dripping from two lower sections: where the pipes meet the muffler directly under the motor, and the stator cover.  I figure these are just natural low points, and not necessarily reflective of the source.  I noticed oil splattered up onto the underside of the tank (right-side sitting), and what appeared to be oil at the cylinder 3 header collar.
Any advice on sequence of troubleshooting is greatly appreciated.  My plan is to first top off oil, then clean the engine so I can better witness the source of the leak(s).
Previous to this ride, I had often started it and let it run for periods of 5-10 min without ever seeing a drip of oil.  Clearly something during the ride caused the issue.  Higher revs maybe?
One more thing to add in case it helps solve the issue: I pulled the plugs after the incident and they look white. I've added a photo in case it points to a related issue.
Thanks for any thoughts on where to start looking.
« Last Edit: September 19, 2020, 02:41:37 PM by BrickWoll »
'77 CB550 K3
Re: Oil Leak Troubleshooting
« Reply #1 on: September 19, 2020, 10:23:53 AM »
For the god knows how manyth time
WHAT BIKE
Offline BrickWoll
« Reply #2 on: September 19, 2020, 10:43:31 AM »
It's in the sig.  '77 CB550K
'77 CB550 K3
« Reply #3 on: September 19, 2020, 11:00:01 AM »
But i never read the sig its too small to see!
If its a 550 the most common oil leaks are the rubber pucks or the crush washers between the steel end brackets and cam cover
Offline BrickWoll
« Reply #4 on: September 19, 2020, 11:26:06 AM »
Thanks for the info.  I'll put those first on the list to check.
'77 CB550 K3
Offline newday777
« Reply #5 on: September 19, 2020, 01:10:00 PM »
Many people have more than one toy.......
Stu
My current rides
Prior bikes....
