Author Topic: Tire Size  (Read 1449 times)
Offline Pwfyrcat1
  • What I'm doing when it's warm
Tire Size
« on: February 17, 2007, 12:27:00 PM »
You know, I have a Clymer manual, but I don't like it too much.
Will a 130/90x16 fit a stock rim on CB400F?
I am thinking the largest I can go is 110/90.
As always, thanks
Just because you can, doesn't mean you should;)
2002 Yamaha Warrior, solo/souped/slammed/fast
2004 Yamaha V Star Silverado, 'The Sedan'
1992 Yamaha TDM 850
1975 Honda CB400F basket case that wants to be something
Offline aptech77
Re: Tire Size
« Reply #1 on: February 17, 2007, 12:29:39 PM »
NO, the rim is an 18"
Offline Pwfyrcat1
Re: Tire Size
« Reply #2 on: February 17, 2007, 12:31:38 PM »
thanks.  :D
So, My question should be, what is the widest tire I can run on the front, w/o changing the forks.
« Last Edit: February 17, 2007, 12:57:25 PM by Pwfyrcat1 »
1992 Yamaha TDM 850
supersport_CB400F
Re: Tire Size
« Reply #3 on: February 17, 2007, 12:55:59 PM »
Offline Einyodeler
  • Midnight bugs taste best!!!
Re: Tire Size
« Reply #4 on: February 17, 2007, 01:51:40 PM »
The general rule of thumb is that you can go 1 size up in width ie from 100/90 to a 110/90.
 Anything wider than that you are pinching the wider tire onto a rim it is not designed for thus ending up actually having less of a contact patch on the road than with the stock size.
Unless you can find a wider rim to respoke onto your hub.
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline Pwfyrcat1
Re: Tire Size
« Reply #5 on: February 17, 2007, 02:03:00 PM »
Thx,
I think I plan on staying with the stock width.  I was window shopping the aisles at ebay.
1992 Yamaha TDM 850
