Author Topic: What engine  (Read 1303 times)
Offline Bashj
What engine
« on: September 22, 2020, 09:04:03 AM »
I picked up a 72 Cb500 with title  and a 73 CB550 with no title. I’m going to resurrect the 72 since it has a title . I will be using a lot of the parts off the CB550 . My question is , is the 550 motor better than the 500? I was debating on swapping it into the CB500 frame. Has anyone done this? Worth the work?
Thanks guys
Offline gary p.
Re: What engine
« Reply #1 on: September 22, 2020, 10:18:02 AM »
Are either running?   Pictures?
Offline newday777
Re: What engine
« Reply #2 on: September 22, 2020, 10:28:14 AM »
Stu
My current rides
Prior bikes....
Offline Bashj
Re: What engine
« Reply #3 on: September 22, 2020, 11:52:04 AM »
Neither are running. The 550 is more a mor complete bike. I have a picture of them. . The tail section is just sitting on it and the tank on the 550
Offline Scott S
Re: What engine
« Reply #4 on: September 22, 2020, 12:53:46 PM »
 I would definitely make the swap. You'll need the 550 clutch cable and the engine bracket that holds the clutch cable.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Bashj
Re: What engine
« Reply #5 on: September 22, 2020, 02:17:08 PM »
Good to know. I’m going to do the swap. I got them both to run briefly off carb spray.
Offline Shtonecb500
    • Youtube profile
Re: What engine
« Reply #6 on: September 22, 2020, 09:43:52 PM »
i would bring everything from the 550 over to the 500 frame.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Re: What engine
« Reply #7 on: September 23, 2020, 02:50:03 AM »
Might want the 550 front forks on the 500 frame if you are interested in dual front calipers on the bike and your 500 right front fork tube is not equipped to allow them.
The Sovereign Man
Re: What engine
« Reply #8 on: September 23, 2020, 04:28:03 AM »
[mention]dave500 [/mention]has a 550 in a 500 frame, he’ll be a good person to ask.
Offline Bashj
Re: What engine
« Reply #9 on: September 23, 2020, 10:35:38 AM »
Yes I plan to swap the forks over as well on to the 500 frame. Thanks for your input guys ! Love this forum
Offline rb550four
Re: What engine
« Reply #10 on: October 06, 2020, 03:53:51 PM »
  I was wondering if one engine has way more miles on it than the other?  I would run the low miler . Have you taken a compression test on both engines yet? I would  adjust the timing chains on both before anything gets taken apart, dump the oil ,  drop the pan and sift through the oil for chunks or other wear, then shine a flashlight up to the timing chain and see if it is slack ( and check for wear marks there) , then rebuild( at least) the top end on  the high miler if no wear was found at the timing chain area on the lower end and keep that engine as the spare should the other one go south.Yes to swapping the wiring to the the 550 harness, the 500 is more primitive but everything is color coded, just plug and play, unless your 500 has  the pin type of harness, then the only swap over that would be needed on the 500 engine if you are going to run that would be the generating system ,include that in the swap from the 550 if that's the case. The 500 transmission is known to be more temperamental than the 550 transmission , and has clutch rods that break once in a while and the adjuster in the lower case cover could have wear from lack of grease or stiff from old grease. Be sure to go through the gears on a center stand to be sure the shifting forks engage and are not frozen before you choose, shifting forks that don't work isn't a good thing to find out about after you make the swap.....means splitting the cases to repair. You must choose wisely Grasshopper.
« Last Edit: October 06, 2020, 04:22:59 PM by rb550four »
Re: What engine
« Reply #11 on: October 06, 2020, 04:42:32 PM »
And then you can do a 650 swap or a 650 top end swap. :D
