Hi new member here, was trying to figure out why my neutral light and oil pressure light both were in op so since they are near each other i figured why not try to kill two birds with one stone. So with the neutral light i took out a piece that is black and rubbery and has a screw going through it. Not too sure on what that part is actually called but that was the only thing i took out that involves working the neutral switch.
For the oil pressure switch all I've done for that was see that power does go to the wire when using the multi meter and when i put a test light onto the wire i would see the oil pressure light come on. So that appears to be just a bad switch. I also took it out.. so I'm not sure if that was a good or bad idea.
But now when i put everything back together I can get the neutral light to come on every time i shift into neutral, but now when i try to go into first the bike just stalls. For additional information when i had that cover off on the left side, for some reason i did pull in the clutch lever, so I'm not sure if that by any chance would've done some sort of damage to the clutch plates.
Any help or advice would be greatly appreciated thank you.
