Author Topic: How's this Stator & Coil look?  (Read 898 times)
Offline bahia
    • William Bay
« on: September 24, 2020, 02:37:31 AM »
Took some persuasion and cussing to get it out of the cover.
I think there's a resistance test I can do, but anything else I should know about these?
How's this one look?
"Bruce" - CB500K2 + 197? 550 forks + Honda tank(maybe)
Re: How's this Stator & Coil look?
« Reply #1 on: September 24, 2020, 03:05:28 AM »
Doesn't look so good.  There must been water under that cover.
Online pjlogue
« Reply #2 on: September 24, 2020, 04:47:35 AM »
The formvar (coating on the winding wires) is cooked.  It needs to be rewound.
-P.
Offline 69cb750
« Reply #3 on: September 24, 2020, 07:28:59 AM »
Stator is bad and rusty from sitting outside engine.
« Reply #4 on: September 24, 2020, 07:30:48 AM »
Ive seen worse work OK you need to do reistance and insulation test
Offline Bodi
« Reply #5 on: September 24, 2020, 01:56:36 PM »
The stator is pretty rusty but if the wire varnish isn't ruined, it will be OK. Measure resistance between the 3 wires - to each other and to ground. Between wires the resistance should be very close to equal, if any are reading low there is probably a short between windings from the insulation going bad. ANY measurable resistance to ground from any wire means the stator is bad.
Be careful with rust removal, chemicals might attack that varnish insulation. Sand off the rust on the inside diameter though to avoid rubbing on the rotor.
The field coil looks OK, these are hard to kill as the windings are protected better. Again. resistance between its wires should be normal and any resistance to ground is bad.
I don't have the expected coil resistance numbers here. Remember that most meters are not very accurate at low resistance, at least touch the probes together and subtract whatever that resistance reading is.
« Reply #6 on: September 24, 2020, 03:22:21 PM »
Idealy use a megger or similar to test to ground rather than multimeter
Online newday777
« Reply #7 on: September 24, 2020, 04:27:57 PM »
I had to look up that one.....megger......
Stu
My current rides
Prior bikes....
« Reply #8 on: September 24, 2020, 05:26:35 PM »
Uses a higher voltage to test the insulation better
Offline grcamna2
« Reply #9 on: September 24, 2020, 05:51:14 PM »
My father's shop used one of those to test electric motor windings  ;)
« Reply #10 on: September 24, 2020, 08:56:47 PM »
Exactly the thing to use!
« Reply #11 on: September 25, 2020, 08:25:21 AM »
Ha, that brings back memories  ;D  My high school was specialized in electrical engineering, our lab hours were very intense, used megger too - just never knew that's what it was called in English.  ;D
Offline grcamna2
« Reply #12 on: September 25, 2020, 09:25:41 AM »
It'll give you a shock,if you hold both the leads..  ::)
« Reply #13 on: September 25, 2020, 09:32:46 AM »
Not that big box ready to release 50.000 V ! Adjustable. Not much current, battery driven.
It look like old style volt meter.
I used one at my work decades ago, electrical motors and harnesses to ensure isolation OK.
Offline bahia
    • William Bay
« Reply #14 on: September 26, 2020, 02:10:26 PM »
I think I'm seeing apples and oranges when it comes to measuring the resistance, so I put together a quick video using the multimeter.
Would love some guidance as to if I'm doing this properly and getting the right readings.
Offline wolf550
« Reply #15 on: September 28, 2020, 11:35:07 AM »
just saw tshrey put his stator and magneto up in the free stuff thread.
74' CB550 (Sold)
71' CB500/550 (Sold)
« Reply #16 on: September 28, 2020, 11:59:25 AM »
If you think it look like isolation issues, only a Megger will show if OK or not.
It will apply high voltage, very low current during a very short time to verify if it will spark thru damaged isolation.
Check between the phases and each phase to "ground", the cover.
Maybe a workshop working with electrical stuff can test it.
Or if it look OK m, measure the resistances written in shop manual
« Reply #17 on: September 28, 2020, 03:43:15 PM »
Only need megger on yellow(s) to ground to check insulation to ground
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=62parvaole2v5nf76su2dr8un6&/topic,60973.0.html
« Reply #18 on: September 30, 2020, 12:23:16 PM »
i have vorked at a industri revinding/elektromotor rep shop..faund this old svedish induktor..it can test/give 1000 volt..it have a vhining saund vhen it spools up to give a impuls..it use a 6 volt battery..it only is a megger in the heigest test power..at lower power it test the vindings..for /shorted vires..as it can read presise miliamps differenses in the vindings..
i got it,,as it not have been used for 25 years
« Last Edit: September 30, 2020, 12:28:24 PM by strynboen »
i hate all this v-w.... vords
