« Reply #1 on: September 27, 2020, 11:30:36 AM »
Maybe the tension was set before you got it? They have a spring to do the setting of the tension and you are not to push extra pressure on the tensioner rod.
You can squirt some WD40 in to lubricate the rod.
If it is noisy when you run it you could get a new gasket for the tensioner, remove the tensioner and inspect it to be sure it moves freely, or clean up the rod so it is moving freely.
![](http://forums.sohc4.net/Themes/default/images/ip.gif)
Logged
Stu
My current rides
Prior bikes....
