Author Topic: A Problem w/ the Forum  (Read 1106 times)
Offline Pwfyrcat1
  • What I'm doing when it's warm
« on: February 17, 2007, 02:36:38 PM »
GOTCHA!
 ;) ;) :D ;D :o 8) ::) :-*
The problem with forum is that it allows an individual like myself to sit around and ponder the possibilities of 'What if..' and 'I wonder'
The only thing worse is a slurpee brain freeze.
So I was reading the topic on switching out the trees/stems/forks/front end, etc and got to wondering what all would be involved if I did that on the 400.  And what if, (see...) on my little 400 I went with a slightly larger diameter up front like ProTeal.  What would I have to change to do that.
Because then I have to toss these questions out to the experts and I get to thinking too much and then I have to go and get a haircut because my karma is all tangled up.
This kind of thinking gets me all wound up and I go window shopping thru the aisles of ebay....musing and saying hmmm...I wonder if that would work;)
Just because you can, doesn't mean you should;)
2002 Yamaha Warrior, solo/souped/slammed/fast
2004 Yamaha V Star Silverado, 'The Sedan'
1992 Yamaha TDM 850
1975 Honda CB400F basket case that wants to be something
Offline Uncle Ernie
Re: A Problem w/ the Forum
« Reply #1 on: February 17, 2007, 08:24:51 PM »
"my little 400 I went with a slightly larger diameter up front "
Larger diameter what?  If you're talking about a tire, it will not handle as well.  Check and see if the tire will rub on anything.
