Author Topic: mUnit - Destroyed  (Read 1652 times)
Offline jakew
mUnit - Destroyed
« on: October 19, 2020, 12:34:25 PM »
Hello out there! I’m curious if anyone has had an mUnit burn up?
I have a 1972 CB500 that I’m in the final stretch of rebuilding. Working through wiring now and went with an mUnit Basic, Rick’s RR, 8 Cell AntiGravity battery.
I had the bike running 10 days ago, everything seemed great. Went out one night to fire it up and the mUnit arched(?). The lock input burned up! I ordered a new one, went through all wiring and confirmed things were fine. My sensing wire from the RR connects to the key wire and then goes into the lock input. I replaced these connections and confirmed all grounds were good on the bike.
Connected the new mUnit, testing each input/output as I added more. Was able to turn everything on (head/brake lights, turn signals, aux) and called it a night. Unhooked the battery. Came back the next night, connected the battery, tested battery at 13.3V, lights in the mUnit signaled I had connection. I turned the key and it arched again! Burned up the same lock input.
I pulled the mUnit to see if I could test it without everything on the bike. Connected the battery/ground, key, and a light with a switch. Turned the key on and nothing happened for about 5-7 seconds…then the same lock terminal started smoking again.
Any ideas? Could it be an issue with the key? I’m using what I had on the original bike.
I used this wiring diagram from Revival: https://technicalarticles.revivalcycles.com/hc/en-us/articles/360009106131-m-Unit-Blue-Basic-Universal-Wiring-Diagram
Thanks for any advice!
Re: mUnit - Destroyed
« Reply #1 on: October 19, 2020, 02:07:19 PM »
Shorting to ground somewhere in that circuit is my bet...
Offline jakew
« Reply #2 on: October 20, 2020, 11:39:20 AM »
Thanks, RAF122S. I appreciate the reply.
I talked to a guy from Revival and he thinks it might be the key switch. I spent a little time testing last night and was able to recreate the problem/fire. All I had connected to the unit was the key switch so it looks to be the culprit. Images of the setup attached including a video of how it burns.
I was also told that in 8 years of working with these he's never had this issue. Has anyone else run into it? Is there a way to confirm it's the switch and not the battery or my ground setup?
Thanks for the help!
Offline albzn
« Reply #3 on: September 27, 2021, 05:39:22 PM »
Hi, quick question. Do you still have the burned out m.units at home? I'm currently working on my own, open-source, type of m-unit and I'm wondering what kind of electronics that are inside!
Thanks in advance
Offline albzn
« Reply #4 on: September 27, 2021, 05:39:55 PM »
Thanks in advance
