Author Topic: Any suggestions for long term gas tank storage  (Read 1300 times)
Offline jamesv220820
« on: November 07, 2020, 12:43:17 PM »
It looks like I am not going to take the bike out this year so I am going to drain the tank, and replace all the petcock parts. Any other suggestions for long term storage for the fuel tank? Should I rinse it out with an additive like mystery oil? Leave the cap open?
There is nothing to fear but fear itself . . . and trying to restore a cb350f
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=i40mkqun4ufa9c9sesib8bn0n3&/topic,60973.0.html
Re: Any suggestions for long term gas tank storage
« Reply #1 on: November 07, 2020, 01:06:44 PM »
i pus a bit diesel inn..and turn it raund..in some month intervall..if i renember it...
i hate all this v-w.... vords
Offline minimo
  • 1977 CB550F 1975 CB400F 1959 Ducati 200 Americano
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: November 07, 2020, 01:41:27 PM »
Add 1/2 can  two stroke oil to a litre of gas. Slosh it around every once in a while. Drain it out in the spring and rinse with fresh fuel.
Offline DaveBarbier
« Reply #4 on: November 08, 2020, 04:05:13 AM »
I use 2 stroke oil too but I just pour in a full bottle only. I make sure it coats the entire inside and when I take it out of storage I just pour in the right ratio of fuel and then drain it in my chain saw gas can.
And keep the lid ON.
Online PeWe
« Reply #5 on: November 09, 2020, 12:38:42 PM »
Store tank in a dry warm room if you do not have a warm dry garage for the bike.
Offline Shtonecb500
    • Youtube profile
« Reply #6 on: November 12, 2020, 10:39:45 PM »
fill it with metal rescue and forget about it.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline DaveBarbier
« Reply #7 on: November 13, 2020, 04:09:59 AM »
Ok...$100 worth of metal rescue (which isn’t a rust preventative by the way) or $3 bottle of 2 stroke oil, hmm. Plus since metal rescue is water based you’ll likely get rust build up because of it at the very top underside of the tank. And it’ll evaporate so you’ll have to top it off every once in a while. Not a great idea.
« Reply #8 on: November 13, 2020, 09:09:50 AM »
I echo Dave's advice.  Metal Rescue is good for removing rust, but not a long term storage medium.  You could clean the tank and coat it with Caswell (epoxy based coating).  THEN, you could forget about it.  As long as you have bare metal inside the tank, I'd coat it with some petroleum-based product, like 2-stroke oil or a liberally-applied spray lubricant like WD-40.  Make sure there is no moisture in the tank before you put it away for storage.
Offline Shtonecb500
    • Youtube profile
« Reply #9 on: November 13, 2020, 05:30:40 PM »
Good point, there is one that leaves a zinc layer behind but it’s like 35 bucks a gallon. How bout just fill it with race gas?
« Reply #10 on: November 13, 2020, 08:29:40 PM »
Race gas would be good if it was ethanol free. Most race gas, however, is not.
Offline 6adan
« Reply #11 on: November 13, 2020, 08:53:05 PM »
 I had a machinist tell me he used ATF on things that needed to be stored a long time. I have my 70 750 tank stored this way and no problems so far and it has been about 3 years.
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
« Reply #12 on: November 14, 2020, 08:38:15 AM »
 Leaded race gas has no alcohol.
