Author Topic: Clear Coating Polished Steel  (Read 5893 times)
Offline MrFry
    • T-Fry.com <--Under Construction
« on: February 19, 2007, 04:17:59 PM »
Hey guys - quick question (maybe)
i decided to polish a spare gas tank for my 750 - and am wondering how i can keep it from rusting
will a clear coat stick to a polished surface?
or is there another way?
Thanks in advance
« Last Edit: February 19, 2007, 04:28:42 PM by MrFry »
Re: Clear Coating Polished Steel
« Reply #1 on: February 19, 2007, 04:59:03 PM »
glisten pc   http://www.por15.com/s.nl/it.A/id.1435/.f      i've never used it but i here it great for polished stuff
« Reply #2 on: February 19, 2007, 05:07:12 PM »
Clear powder coat is available. I saw a tank done where they put a powder color on to resemble weld burns then clear powder over the entire tank. Looked good enough to make me think it was a raw tank with weld burns on it.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #3 on: February 19, 2007, 05:08:37 PM »
Eastwood  sells a Gloss Clear that is fuel and heat resistant.
Just got 3 cans in the mail. Haven't used it yet ;D
Offline Green550F
  • Nothing is as cool as that which you made.
« Reply #4 on: February 19, 2007, 06:16:25 PM »
Zoot Seal is made for pollished Aluminum, don't know how it'd work on steel?
93 Kawasaki Voyager XII
70 Honda CL350 Cafe
Zane
« Reply #5 on: February 19, 2007, 11:07:24 PM »
I found out you can get a clear powder coat done when I was looking around to powdercoat my carrier rack.
What I'm interested in, with a tank, is how one would go about protecting a decal (assuming of course, that you wanted to put one on the thing).
So I guess I have one and a half questions.
Can you powdercoat over a decal and/or can you put on two layers of powdercoating?
Offline greenjeans
  • 1972 CB750K2
« Reply #6 on: February 20, 2007, 08:22:41 AM »
*Guess I should have read the post first*
 My reply is really for automotive paint.  I've clear-coated a couple tanks with good results
(2 yrs still good - I do store inside etc.)
I've used a urethatne clear w/ hardener... the trick is to put down several 3-4-5 mist coats -
just spray it to where it just kinda "glistens"  don't lay it on wet.  Let it flash in between coats.
Let the last misting coat flash a few extra minutes  before putting a final coats on it.  The first
final coat- not so thick, the second you can lay on wet.
I've also cleared directly on top of decals as well.  Those are kinda touchy though.  If they are true decals, the mist coats are a must.  If they are vinyl decals, it kinda depends on the type of adhesive that is on the back... some are water-based adhesives and some are solvent/acrylic  based.
I've found that just putting a bunch of mist coats keeps the solvents from attacking the adhesive as bad as they would if you just layed it on wet.
That being said....  I sure would like to see the clear powder coat after a few years in the sun.
That seems like it would be the surefire way to go.   Only problem in coating over decals.
Are your decals original, or are they after market vinyl decals?
« Last Edit: February 20, 2007, 08:25:03 AM by greenjeans »
Offline MrFry
« Reply #7 on: February 20, 2007, 08:27:00 AM »
mine are kragen pin-stripe...
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #8 on: February 20, 2007, 11:14:55 AM »
I would think if you have a solid layer/coat of some sorta alum. polish and keep the
tank outta the rain (as much as possible) the finish would holdup. As with any powdercoating/clear
you are gonna loose some kinda luster...
Offline MrFry
« Reply #9 on: February 20, 2007, 02:16:21 PM »
Just ordered the POR glisten pc - it should be here tomorrow
i'll keep you guys updated
perhaps i need to start a thread documenting my build?
Loas 78 CB750K
« Reply #10 on: March 02, 2007, 12:12:05 PM »
Just read this review:
"ZoopSeal Original Sealer
"I used Zoop sealer while building a motorcycle. I had a lot of polished aluminum and I didn't want to spend all summer polishing instead of riding, so I asked for Zoop Sealer for a x-mas gift. I used Zoop sealer on about half of my polished aluminum, and the other half was left untreated due to the schedule of everything. Within 2 months of riding I had to repolish all the aluminum, so I am sad to say the Zoop Sealer made absolutely no difference at all. Complete waste of money, and time." - Eric Barnett, Flint, MI"
It was the only one I saw on that site.
Offline MrFry
« Reply #11 on: March 02, 2007, 12:18:32 PM »
Thanks^^
i've decided to go with a clear powdercoat (assuming i keep this tank - check my other thread for problems)
