Author Topic: stock rear disc question, rotors the same pattern?  (Read 856 times)
Offline Shtonecb500
    • Youtube profile
« on: November 26, 2020, 04:25:41 PM »
would a rear disc rotor from a later comstar fit the 75/76 F spoked hub that accepted a rear disc?
I looked up bike diagrams and it looks like there might be an offset behind the comstar disk.
« Last Edit: November 26, 2020, 04:28:10 PM by Shtonecb500 »
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Re: stock rear disc question, rotors the same pattern?
« Reply #1 on: November 26, 2020, 05:14:33 PM »
First F models with wire wheels have huge hole in center , not sure if they are 6 bolt. I know co-star front are 5 bolt, not sure about rear..
« Last Edit: November 26, 2020, 05:26:34 PM by 754 »
« Reply #2 on: November 26, 2020, 06:07:32 PM »
I am about 55 percent sure (that's not very sure lol) that spoked wheel f rear disc and comstar rear disc are interchangeable
« Reply #3 on: November 26, 2020, 06:28:00 PM »
The ' 7 and 78 F has thin discs up front, mog sure how thick the rear is .i know rear caliper is same as one side of the front far as I know.
 The rear 75 and 76 F rotor is thick like K model fronts, iirc..
Offline Shtonecb500
    • Youtube profile
« Reply #4 on: November 26, 2020, 08:59:19 PM »
Im only concerned with the rear, I can get my hands  on comstar rear wheel, Ill steal the rotor, caliper and other hardware...I sourced a 75-76 spoke hub on eBay for 130 bucks...I could piece together a rear disc set up for under 200 if thats the case.
« Reply #5 on: November 26, 2020, 10:25:50 PM »
Count the mounting bolts , on each ..first step..
Offline Shtonecb500
    • Youtube profile
« Reply #6 on: November 26, 2020, 11:50:41 PM »
looks like they are the same rotor based on the pictures I found.
Im gonna start hunting down parts. I think with my extended swing arm the rotor wont look SO chunky back there like it usually does. Im only going to do it if I can keep it all under $200 for parts. Ill check back in when ive made some progress.
Offline Shtonecb500
    • Youtube profile
« Reply #7 on: November 27, 2020, 10:21:42 AM »
you can be more like 95% until i slap one on.
« Reply #8 on: November 29, 2020, 09:14:23 PM »
Looks like the rotors have the same part number?
Offline robvangulik
  • Honda Fourever
« Reply #9 on: November 30, 2020, 01:20:14 AM »
Yep, same part# 43120371000 for both F and F2.
