Author Topic: hand control refurb and get on/off switch cap off  (Read 593 times)
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« on: November 28, 2020, 08:04:05 PM »
did a bit of searching couldn't find anything on this but sure it's there.  want to remove the kill switch and clean up both hand control finishes.  thanks.
cb750 k6 - ugly
Offline flatlander
Re: hand control refurb and get on/off switch cap off
« Reply #1 on: November 28, 2020, 11:47:37 PM »
here's sohron's description. unfortunately the pictures have disappeared but the descriptions might still be helpful:
http://forums.sohc4.net/index.php/topic,80532.0.html
Offline pjlogue
« Reply #2 on: November 29, 2020, 03:07:24 AM »
The red kill switch is held in by an E clip on the underside of the switch.  Be careful removing this as there is a small spring and ball (real small) under the switch which can go flying.  Clean everything well and check that the lead contacts on the switch terminals aren't shorted together.  This can happen because the current load can soften the solder and bridge the gap between terminals.
Best to use either a marine grease or silicone vacuum grease to lube the switch.
-P.
