One of the many, many parts that my basket case that I have been working on is the speedometer cable.
Full thread here
http://forums.sohc4.net/index.php/topic,184928.0.htmlI purchased a new one that should fit my model but it does not appear to fit into the wheel housing properly. Everything else on it looked fine. I messaged the supplier, they suggested maybe I have a different speedometer gear, perhaps one from a CB650 standard. So I purchased that one as well. Not only does that one not fit into the housing but it is also too short. The one intended for the Nighthawk is a few inches longer, does the Nighthawk have a longer rake?
Anyway, the speedometer gear looks to be original, at least it matches what I can find to compare it to. So I am a little unsure of how to get this resolved.
Here is what I am seeing.
The cable fits in and and it will kinda stay in with the clip but it is very loose. Like it pulls out super easy and seems like it would fall out the first time i hit a bump. Plus, there is an O-ring on the fitting that does not even make it to the housing. So it seems like it needs to go in farther.
I checked the housing multiple times to see if something is stuck in there but it sure doesn't look like it.
Other than this, the cable seems fine, it is long enough to go to the speedometer and it seems to fit like it should. This seems like such a simple thing, I am not sure what I am missing. Perhaps there is another part I should have?
Here is a comparison of the 2 cables
Standard on the left, Nighthawk (mine) on the right
The Nighthawk cable is longer and fits properly, the standard cable it too short.
Any insight is appreciated
I suppose it is also possible that this is the way that it is supposed to be. Since it was missing when I got the bike, I had nothing to compare it to. It just doesn't seem quite right though.
