Author Topic: torque spec for nuts on rear sprocket  (Read 1889 times)
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« on: December 03, 2020, 04:03:32 PM »
where should i set my wrench for this?
cb750 k6 - ugly
Offline evinrude7
  • not a kung-fu
Re: torque spec for nuts on rear sprocket
« Reply #1 on: December 03, 2020, 04:33:29 PM »
not finding it in the shop manual
cb750 k6 - ugly
Offline Flyin900
« Reply #2 on: December 04, 2020, 12:09:15 AM »
On the CB 550 it was 16-20 ft lbs. The nuts also have a lock collar that was bent up around the nut to stop any movement.
If your working from a Honda FSM then there isn’t normally specs for torque in the individual sections. You will find the master specs together at the beginning of the shop manual. Where the frame/engine/misc torque specs are individually listed on a couple of pages.
« Last Edit: December 04, 2020, 12:18:22 AM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline robvangulik
  • Honda Fourever
« Reply #3 on: December 04, 2020, 01:34:22 AM »
Offline evinrude7
  • not a kung-fu
« Reply #4 on: December 04, 2020, 06:08:14 AM »
that's where i was heading this morning to look.  it's a bit lower than i anticipated.  have the lock collars.
cb750 k6 - ugly
Offline evinrude7
  • not a kung-fu
« Reply #5 on: December 04, 2020, 06:08:56 AM »
cb750 k6 - ugly
Offline evinrude7
  • not a kung-fu
« Reply #6 on: December 04, 2020, 05:05:52 PM »
Is this normal because of the cush drive? Or because it's off the bike and not fastened to the swing arm?  video attached.
Sent from my moto g(7) using Tapatalk
« Last Edit: December 04, 2020, 05:13:41 PM by evinrude7 »
cb750 k6 - ugly
« Reply #7 on: December 04, 2020, 06:40:02 PM »
both...with all correct spacers in place and axle nut tight, it can't wobble like that anymore
Offline evinrude7
  • not a kung-fu
« Reply #8 on: December 04, 2020, 07:04:34 PM »
Thanks sb41
cb750 k6 - ugly
