Author Topic: 64mm piston rings  (Read 643 times)
Offline D DIAMOND
64mm piston rings
« on: December 05, 2020, 02:46:13 AM »
i have a set of 64mm pistons and rings the oil ring has a oval mark with a mark through on the right of the gap so i assume it is the top
the middle ring which is a darker colour than the top ring has a R right of the gap which i think is the top the one which i think is the top ring has a chrome finish but no marks but the top 2 rings have a very slight lip on the underside sorry it is so hard to explain
will clean the pistons to see if any marks DD
Offline 69cb750
Re: 64mm piston rings
« Reply #1 on: December 05, 2020, 05:04:20 AM »
Letter is ring top, 2nd ring has inside groove (sometimes).
Offline D DIAMOND
« Reply #2 on: December 05, 2020, 07:24:56 AM »
hello both the top and second rings have grooves are they both to underside is the top ring the shiny ring does this ring want the groove to the underside  have added 2 photos of rings 005 is what i think is the2nd ring 005 is what i think is the top ring DD
« Last Edit: December 05, 2020, 07:30:27 AM by D DIAMOND »
Offline Bodi
« Reply #3 on: December 05, 2020, 11:36:35 AM »
Those are pretty bad pics.
The top (compression) ring is usually flat but I suppose it could be slightly tapered, if tapered the taper would instinctively go thick side up to hold compression.
The second (oil control) ring is always tapered and goes with thick part down, to scrape oil down off the bore.
The oil drain ring assembly, I don't believe the thin rings have any taper but I think they should scrape down if they do.
