Author Topic: Complete engine worth  (Read 913 times)
Offline zxshep
« on: December 06, 2020, 07:09:58 PM »
Moving along with the freshening up of my CB400.  About ready to begin reassembling the rear end.
I have a complete spare engine - all covers, full set of carbs, starter, the whole shooting match - that I am thinking of selling.
What's the value of a complete engine?  It does need some TLC and polishing, but everything is there.  I really don't have a use for it, and hate to see it sit for another 25 years.
Thanks for your time and input.
2005 CR125R
1975 CB400F
Online Kevin
Re: Complete engine worth
« Reply #1 on: December 06, 2020, 08:45:49 PM »
That all depends on a lot of things. The biggest factor being how close it is to someone who needs it.
Are you able to do a compression test on the cylinders?
The carbs add a lot to the value, if they are clean and usable.
It is probably worth more in parts than as a whole...but that takes time, and time =$.
Where are you located?
Sent from my SM-N960F using Tapatalk
A couple of 400F's and a
'98 Suzuki Intruder VS1400 ~ for long rides
Offline zxshep
« Reply #2 on: December 06, 2020, 08:52:16 PM »
I'm located in NC.
Not able to do a comp test on the cylinders.  One of the tools I don't have.
Yeah, to ship this thing would be crazy expensive.  It was a bit of a chore getting it loaded into and out of the truck!
I appreciate the feedback.
2005 CR125R
1975 CB400F
Offline robvangulik
  • Honda Fourever
« Reply #3 on: December 07, 2020, 02:42:44 AM »
It is the least heavy of all the fours, along ofcourse with the 350, I measured one on request some time ago, it is manageable on your own with 60 kilos.
« Reply #4 on: December 07, 2020, 06:41:18 AM »
$200-300...if you can find a local buyer.  Shipping a motor is typically a deal killer.
Just keep it, that way you wont need it!
Online carnivorous chicken
« Reply #5 on: December 07, 2020, 07:11:29 AM »
I've sold a few engines including 400Fs, and that's about right, maybe a little high with unknown compression and not coming from a running bike.
Shipping through u-ship or Greyhound for engines is the cheapest.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #6 on: December 07, 2020, 07:43:41 AM »
Would engine number figure into the value?
Someone will want that engine I'm sure.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #7 on: December 07, 2020, 08:05:15 AM »
Not as far as I know. There aren't the same variations/changes over time as there were with the 750, nor desireability of the earliest engines. I think the last year of production there was a change to the engine studs to stop weeping oil, but that's it as far as I know. Some foreign (outside USA) 400Fs had a shorter stroke. And someone might want an engine that more closely matches their frame #.
« Reply #8 on: December 07, 2020, 04:32:31 PM »
  Buying an unknown engine is kind of risky if your hoping for a plug and play. I just bought a 750 F1 today without a title that I may be parting out this winter though not sure yet. My plan is to see if I can get the engine running first then make a video or try and sell it running in the frame for a person to see. If it sounds too good it will probably go into my stash with all the others I'll never use  ::)
« Reply #9 on: December 07, 2020, 05:48:57 PM »
What you effectively have is a spare parts engine unless someone can see it running
Offline zxshep
« Reply #10 on: December 07, 2020, 08:36:03 PM »
Thanks everyone.  I appreciate all the input.
2005 CR125R
1975 CB400F
