Author Topic: Anyone ever use Emgo 530 rear sprockets?  (Read 602 times)
« on: December 07, 2020, 03:47:18 AM »
Anyone ever use Emgo branded rear sprockets? I ran across some for the cb550 and they are clearance priced around $12.50, normally 19.50.  Is it worth the savings or will they be like a lot of other Emgo stuff, cheap junk...?
JT Sprockets rear sprockets are $26-30+, depending on source.
Thanks!
Offline rotortiller
Re: Anyone ever use Emgo 530 rear sprockets?
« Reply #1 on: December 07, 2020, 04:20:48 AM »
It's pretty hard to screw up a rear sprocket but then again some guys could screw up the lords prayer; provided they actually knew how it went LOL.
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: December 07, 2020, 05:57:51 AM »
Unless you are planning a huge trip, they are fine.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #3 on: December 07, 2020, 07:44:41 AM »
Hondaman has a lot to say about sprockets I'm sure.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #4 on: December 07, 2020, 08:25:44 AM »
I have used them.  They are better than some other brands...lasted 20 some thousand miles with an oring chain...that tou cant use on a 550
