Author Topic: Squirrel 3.0  (Read 16211 times)
Re: Squirrel 3.0
« Reply #175 on: July 23, 2021, 09:38:40 AM »
Good heavens... That's a brilliant idea!!!
I wish I'd thought of that.   ;)
I'll be giving all props to you Sir if I can pull this off. But I might also open up a side hustle where I'll make these and claim the fame. If they look half as good as yours do I'll be right as rain. And I'll steal part of your business name but put a fish spin on it and go with Codffery's.
Codffery's sounds much better than Lamprey's.  River: did you get those lampreys to let go of your legs?
Offline Godffery
  • Godffery's Garage
Re: Squirrel 3.0
« Reply #176 on: July 23, 2021, 07:56:35 PM »
I used a Tarrozi fork brace and mounted the fender to the bottom of the brace.
Kelly do you have any more pics of how you skinned this feral cat?
I do but they are too big to post here. I made two 2" X 3/4" x1/16" metal strips with a hole in each end to hold the fender to the brace. I drilled and tapped holes in the angled face on each side of the brace and attached the fender with stainless button head screws. It takes a little finagling to get the holes located on the brace and an extra set of hands helped a lot.
I've done one like that as well, and I can confirm it was a bit of a bugger getting everything in the right position, but did make for a rather simple solution.  Although I did notice some issues with installing & removing it, so that method made things like brake / fork / wheel maintenance more time consuming.
 I eventually settled on a method that has the ability to separate the brace from the fender, threw the top.
Re: Squirrel 3.0
« Reply #177 on: August 18, 2021, 12:58:01 PM »
Alright already! Put a front sprocket on this bike and ride it!!
Re: Squirrel 3.0
« Reply #178 on: August 18, 2021, 02:05:15 PM »
No kidding!  Is he stuck out at the river?!  Now his excuse will be school starts soon...
Re: Squirrel 3.0
« Reply #179 on: August 18, 2021, 02:19:06 PM »
It already has restarted in AZ and 581 cases of Covid in schools as of the other day...
Re: Squirrel 3.0
« Reply #180 on: August 18, 2021, 02:20:52 PM »
How is your wife doing River?
Offline river
Re: Squirrel 3.0
« Reply #181 on: August 19, 2021, 07:30:03 PM »
Fender is back together. Turned out really nice.
90 by Chris Neumann, on Flickr
Since I won't use the fender braces any longer, I installed spools up front.
91 by Chris Neumann, on Flickr
92 by Chris Neumann, on Flickr
I have 12mm of clearance between the tire and the fender and a touch less than 4mm of clearance between fender and brace. Really happy with how the front looks.
Squirrel 1.0 http://forums.sohc4.net/index.php/topic,127186.2050.
ml
Squirrel 2.0
http://forums.sohc4.net/index.php/topic,176846.msg2055831.html#msg2055831
Squirrel 3.0
http://forums.sohc4.net/index.php/topic,185362.msg2146449.html#msg2146449
Re: Squirrel 3.0
« Reply #182 on: August 19, 2021, 10:00:27 PM »
Looking great!
Re: Squirrel 3.0
« Reply #183 on: August 20, 2021, 12:25:37 AM »
Very clean good looking work!  Have you taken her out for a ride?
Re: Squirrel 3.0
« Reply #184 on: August 20, 2021, 04:30:06 PM »
Still needs a front sprocket. He could duck walk it!
Offline river
Re: Squirrel 3.0
« Reply #185 on: August 21, 2021, 05:27:03 PM »
I am trying to locate some nice looking bolts to hold the rear sprocket to the carrier and am having a real difficult time. They are m12 1.25. Can anyone point me in the right direction?
ml
Squirrel 2.0
Squirrel 3.0
Offline Jimcg
Re: Squirrel 3.0
« Reply #186 on: August 21, 2021, 09:20:00 PM »
Your bike looks great!
Check if these guys can provide the bolts you need. That's what the do:
https://www.pro-bolt.com/
/Jim
1982 CB650Z RC03 owner in Eskilstuna, Sweden
About my bike:
http://forums.sohc4.net/index.php/topic,183848.0.html
Just the pictures and no text:
https://www.flickr.com/photos/189154615@N04/?
Offline river
Re: Squirrel 3.0
« Reply #187 on: August 22, 2021, 08:38:04 AM »
Thank you for the link Jim. They actually do have m12 x 1.25 bolts but they only have them in titanium and those are about $30 a piece!! :o
ml
Squirrel 2.0
Squirrel 3.0
« Last Edit: August 22, 2021, 08:57:00 AM by RAFster122s »
Offline Jimcg
Re: Squirrel 3.0
« Reply #189 on: August 22, 2021, 11:10:29 AM »
Ooops, that was... EXPENSIVE!!!
/Jim
About my bike:
Offline river
Re: Squirrel 3.0
« Reply #190 on: August 22, 2021, 04:01:44 PM »
Thanks David. I found some that will work. I really wanted something like ARP 12 point but they don't seem to make anything like that.
Jim...I'd love to add a little bling with those golden ti bolts but goodness that's pricey.
ml
Squirrel 2.0
Squirrel 3.0
Offline river
Re: Squirrel 3.0
« Reply #191 on: August 29, 2021, 05:49:15 PM »
Friday night I was able to get the chain installed and the back of the bike together.
95 by Chris Neumann, on Flickr
I spent time Saturday morning reinstalling the rearsets, linkages, exhaust, and some other small stuff. On Friday night the axle nut felt bad when I tightened it down. I needed to adjust the chain on Saturday and the nut stripped and wouldn't tighten or loosen. So I had to grind the nut off. Luckily, I had another axle and nut and it worked. I also loosened the left side spokes a touch on the rear wheel and tightened the right side a hair to pull the rim/tire to the right slightly.
93 by Chris Neumann, on Flickr
Not thrilled with the muffler support and may do something else down the road. Took it for an easy 45 minute ride today and everything seems great. The rearsets are very comfortable and go nicely with the 400 bars. I still need to mount the fender to the Tarozzi brace and am wavering on how to go about it. This conversion was much more challenging and stressful than I thought it was going to be. I'm thrilled with how things look. Thank you everyone for the help!
94 by Chris Neumann, on Flickr
ml
Squirrel 2.0
Squirrel 3.0
Re: Squirrel 3.0
« Reply #192 on: August 29, 2021, 06:08:41 PM »
 :D ;)
Offline Godffery
  • Godffery's Garage
Re: Squirrel 3.0
« Reply #193 on: August 29, 2021, 09:05:17 PM »
 The project might have been much more challenging and stressful than you anticipated, But you have gained more knowledge & experience then you could ever have gotten from any classroom, and I suspect it has also come with a great deal of satisfaction with the conquering of each challenge.
 Side note:
There is one down side of all that work; Only those who have put forth similar effort & dedication, will even come close to actually appreciating what it took to achieve.   ;)   Yet likewise; you now have greater discernment when viewing such work of others.
Re: Squirrel 3.0
« Reply #194 on: August 29, 2021, 10:30:34 PM »
Wow, those new wheels and tires look fantastic, Chris.
Offline river
Re: Squirrel 3.0
« Reply #195 on: October 10, 2021, 06:11:07 PM »
I realized I never updated this with how the fender turned out. Because I've been so busy with work and some other crap, I decided to drop Squirrel off at a friend's metal fab business while I went to 6th grade camp for two weeks. He took care of the fender and I couldn't be happier with how it turned out. He also surprised me with this strap to secure the muffler that looks so much nicer than the spring did.
96 by Chris Neumann, on Flickr
97 by Chris Neumann, on Flickr
98 by Chris Neumann, on Flickr
99 by Chris Neumann, on Flickr
ml
Squirrel 2.0
Squirrel 3.0
Offline river
Re: Squirrel 3.0
« Reply #196 on: March 24, 2023, 10:17:33 PM »
Wanted to post a minor update to Squirrel. I'm always looking to learn new things and I've always been intrigued with old school sign painting and gold leaf work. My side covers needed new paint anyways so I figured why not try something on them. True artists do everything freehand so I did cheat a little and had stencils made of the numbers I wanted to run. I used the stencils as a guide for brushing on the size (adhesive).
Funny story related to the particular number I chose. I get a call from an upset parent about his child being given 2 lunch detentions from his math teacher. On a recent quiz, as part of the beginning instructions, it says, "Write any number next your name." Child writes the number 69 and teacher is, "highly insulted." Parent argues that his child (7th grade boy) doesn't know that 69 has anything to do with regard to a sexual reference. Normally, I would direct the parent back to the teacher but I knew I could extinguish things quickly so I tell him I'll have a conversation with the teacher. I do and offer some suggestions such as steering things in the direction you want them to go (write a number between 1 and 30, write a number that contains the following provided digits, etc.). Then at a team meeting a few days later we're talking about our weekends and I share a picture of my work on the side covers and we all had a good laugh.
Obviously, my choice for the number had more to do with a nod to Nicky Hayden than a sexual innuendo that middle school students find to be funny and new teachers find offensive. The leaf work was easier than I thought it was going to be and now all I see are signs on trucks and the like that should be done in this fashion. The outlining was extremely difficult. I still need to clear the covers. This kind of stuff really is a lost art and that's sad.
550 by Chris Neumann, on Flickr
ml
Squirrel 2.0
Squirrel 3.0
Offline river
Re: Squirrel 3.0
« Reply #197 on: March 24, 2023, 10:22:52 PM »
Prior to outlining but really shows the turned leafing.
69 by Chris Neumann, on Flickr
ml
Squirrel 2.0
Squirrel 3.0
Offline river
Re: Squirrel 3.0
« Reply #198 on: March 24, 2023, 10:26:11 PM »
The only picture with a cover on the bike.
550 3 by Chris Neumann, on Flickr
ml
Squirrel 2.0
Squirrel 3.0
Offline wolf550
Re: Squirrel 3.0
« Reply #199 on: March 25, 2023, 07:15:02 AM »
I can always remember my first time hearing that number from bill and teds excellent adventure.
being 8 at the time I asked my mom what that means? she told me just watch the movie.
74' CB550 (Sold)
71' CB500/550 (Sold)
