Author Topic: Anyone know how to take this off?  (Read 4529 times)
Offline juntjoo
Re: Anyone know how to take this off?
« Reply #25 on: December 30, 2020, 12:51:59 PM »
when you bend the indicator
Well I'd have to agree with you that that is common enough a repair, which BTW it was the PO! not me, but clymers apparently doesn't agree. Plus mine is the rare model with special sections for it. But it's a pretty good manual I'd have to say. If the pics were a bit higher resolution in color that would be awesome
Is your bike a DOHC 650 or a SOHC 650 🤔
SOHC
-Ben
82 Nighthawk 650..
1982 Honda Nighthawk...
I HAVE A 1982 HONDA NIGHTHAWK FFS! j/k. It's my only bike, my first and last.
Offline juntjoo
« Reply #26 on: January 04, 2021, 02:56:01 PM »
Those aint Honda ones, you can see connecors in the pic with the big hole, did you honesly think Honda fitted a loom with everything hard wired on the assembly line?
I'm ignorant of this stuff. If I had to guess they hard CONNECTED it somehow. But looks like they're heat shrink wrapped. So I can just disconnect these and reconnect them? I've never messed with these connections.
Speaking of heat shrink wraps. I've bought some in the past and used a torch to hear them and they all inevitably just burn, not shrink. Is there a skill to it or do you just need the proper heat gun tool? A hair dryer didn't work at all.
If you are looking at the original Honda bullet connectors, there is no shrinkwrap. Just a rubber, outer case. The female socket stays in the black rubber tube, the male 1/2 of the connector comes out whenyou pull them apart. Assembly is the reverse...
These guys! Found this off my stator. Couldn't get the Philips head screw off, stripped it actually, that holds this in place without realizing it was this detachable type. Started wiggling it hoping it might free up and it did. Good to know.
-Ben
82 Nighthawk 650..
Offline carnivorous chicken
« Reply #27 on: January 04, 2021, 03:59:41 PM »
Your bike doesn't have phillips screws, they're JIS. You need a JIS driver or, as you have discovered, the heads will strip.
Offline juntjoo
« Reply #28 on: January 04, 2021, 04:13:09 PM »
Is that what these are? I heard that before. Whatever they are I can't budge em with my arm and screw driver. I didn't strip em with a hand driver but with an impact wrench. Are you supposed to use a an impact with these, as they're often big and been in place for a long time. Either way, wherever I find em I'm replacing them with Allen bolts
-Ben
82 Nighthawk 650..
Offline StockRider
  • Sustaining SOHC/4
  • Well, I thought it was stock...
« Reply #29 on: January 04, 2021, 04:53:19 PM »
First image below.
NOT second image.
'70 CB750K0 - "Truck" | 4x4 | 4 Cables/4 Carbs/4 Cyls/4 Pipes | PO: "Old J.O.", a.k.a. Dad, Ride Free Brother!
Offline juntjoo
« Reply #30 on: January 04, 2021, 06:44:54 PM »
First image below.
NOT second image.
Ah.. Now where do you find these screws mostly? Older Japanese bikes? Cars? I don't think I've run into them with cars. If not I won't invest in this tool unless I keep getting older Japanese bikes and as needed I'll just replace mine with better bolts/screws
-Ben
82 Nighthawk 650..
Offline Alan F.
« Reply #31 on: January 04, 2021, 09:22:52 PM »
....If not I won't invest in this tool unless I keep getting older Japanese bikes and as needed I'll just replace mine with better bolts/screws
I've had shallow (and shallower) pockets at times, this is a tool that is not just for this type of screws, but is a classic and indispensable solution when needed.
Here's an inexpensive example from a time honored source:
https://www.napaonline.com/en/p/BK_7769059?cid=paidsearch_shopping_dcoe_google&campaign=GSC-Tools-Equipment&campaign_id=8553470562&adgroup_id=107047174069&adtype=pla&gclid=Cj0KCQiAlsv_BRDtARIsAHMGVSbGSy4oLtg3Km-eqrv3T063TSTXdwltDAXg2rRBOgH4RKe2ow9fdskaAgHgEALw_wcB
$15.99 at NAPA for everyone not clicking.
« Last Edit: January 04, 2021, 09:24:43 PM by Alan F. »
Offline juntjoo
« Reply #32 on: January 04, 2021, 09:54:04 PM »
Yeah I've seen these just never thought to need them. Are they specific for unscrewing big screws? I'll probably grab one then if they're not that much
-Ben
82 Nighthawk 650..
Offline Alan F.
« Reply #33 on: January 04, 2021, 10:26:15 PM »
For removing screws, bolts, etc.
The difference with one of these is that it pushes the Philips (or whatever) bit into the stuck fastener as it applies torque to loosen (or tighten) so that the bit won't slip and just bugger the screw head.
I've used mine on lots of different parts of bikes.
Offline StockRider
  • Sustaining SOHC/4
« Reply #34 on: January 05, 2021, 01:53:44 AM »
I think this is still on topic.... :P
The Top Ten Most Essential Tools for Motorcycle Riders (not that I agree with the lists..., to each his own):
https://www.bikebandit.com/blog/the-top-ten-most-essential-tools-for-motorcycle-riders
The hilarious thing is that motorcycle.com did an article 6 months later and included a powered Impact Driver instead of a handheld Impact Driver..., hopefully they know the difference.
https://www.motorcycle.com/top10/top-10-must-motorcycle-tools.html
Offline juntjoo
« Reply #35 on: January 12, 2021, 06:03:36 AM »
Thanks for the recommendation. Got me mine. And got my stator/regulator in the mail and my old one is stuck in with a rounded JIS. Can't wait to use it!
-Ben
82 Nighthawk 650..
Offline kerryb
  • Not a very
« Reply #36 on: January 12, 2021, 03:07:09 PM »
I always start with the (hand) impact driver if it is the first time I have removed an old jis screw.  10 bikes, and never ruined a screw that was good when I started.  USE the impact driver first!
Now, to get that rounded, stripped screw out you may have to cut a new slot in it with a dremel tool and a skinny cut-off wheel.  Then you can use the impact driver with a straight blade bit.
Editorial comment:  if you are riding an old bike to save money, you have to invest in the basic correct tools and a FACTORY service manual.  The money you save by not breaking stuff will more than pay for the tools.  The money you save by not taking it to a shop will pay for the bike!  Clymer gets their pics by copying the factory service manual so the pictures lose the resolution you need to see the details.
I have the bike you are working on, '82 cb650sc,  it take 10 to 15 minutes to disassemble the seat and rear bodywork to get to all the wires and fasteners that you want to work with.
Offline juntjoo
« Reply #37 on: January 12, 2021, 03:21:31 PM »
That's exactly what I did. I know that trick with the cutting wheel. I might have forgotten it at first. I learn so many more things DIY'ing than actually thoroughly applying them like you'd do if it were a job or regular hobby that I often get stuck on things I've actually dealt with before. I often start a thread then delete it. I need to slow down and think, with everything in life...I will be using this impact driver a lot. I like it. IDK how I never knew about it before. And I've got my eye on that service manual. I think I saw it for like $100. I'm sure it's worth it. Plan on getting it maybe before next repair(lol, it's become an expectation) but after I get my charging issue solved I have a feeling I won't have any problems for a long time. And I'm good on this thread. I know how to get in there and disconnect the Honda connectors. Didn't know about them before. And I got a good idea how I'm gonna bend this hand rail back.
« Last Edit: January 12, 2021, 06:11:44 PM by juntjoo »
-Ben
82 Nighthawk 650..
Offline scunny
  • don't call me expert
« Reply #38 on: January 12, 2021, 08:25:22 PM »
I've got a 1980 650Z, all the case bolts have 8mm hex heads, the only JIS screws are on the oil pump and carb bowls from memory ?
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
