Author Topic: '73 CB750 Leaking carb bowl - fix or replace?  (Read 1090 times)
Offline gpzkat
« on: December 26, 2020, 08:09:49 PM »
I got a replacement float bowl due to one of mine having a broken drain plug which was buggered.  But the replacement leaks, I filled it up with gas and it drips out steadily.  So I'm 0 for 2.  I sort of doubt there is a way to fix it properly, but if anyone has done this let me know.  It's dripping out of the overflow tube, looks like a press fit brass into aluminum.
Otherwise if anyone has one let me know, I can live with one that's not a #3 as well, just want a non-leaker.  I have quite a few decent parts to offer up as trade or let me know your price.  Thanks!
« Last Edit: December 26, 2020, 08:13:52 PM by gpzkat »
Offline onepieceatatime
Re: Leaking carb bowl - fix or replace?
« Reply #1 on: December 26, 2020, 08:13:19 PM »
What bike or carb model?
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline gpzkat
« Reply #2 on: December 26, 2020, 08:14:26 PM »
Modified the title to '73 CB750, thanks. Am tired.
« Last Edit: December 26, 2020, 08:27:39 PM by gpzkat »
Re: '73 CB750 Leaking carb bowl - fix or replace?
« Reply #3 on: December 26, 2020, 09:22:41 PM »
If it's dripping from the overflow tube, there are two common causes..
1 The float is not performing it's job shutting off the fuel when the bowl is full
2 The brass overflow tube has a split or crack, allowing fuel to seep through. There are several ways to repair split tubes.
Offline gpzkat
« Reply #4 on: December 26, 2020, 10:05:22 PM »
I took the bowl off and held over the sink, filled each one up and the one leaks even half filled.  I will try a test tomorrow with a vacuum pump to find out more.
« Reply #5 on: December 26, 2020, 10:14:00 PM »
Sounds like a cracked/split overflow tube...
Offline gpzkat
« Reply #6 on: December 27, 2020, 10:41:16 AM »
Yeah it is the overflow tube, easy enough to sleeve it for a quick fix.
Offline gpzkat
« Reply #7 on: December 28, 2020, 01:48:43 PM »
I soldered it, worked fine and took for a spin today, using a friend's tank that I de-rusted with vinegar for 3 days, then nuts/bolts in hot water with baking soda, then acetone and finally threw some Marvel Mystery oil I had laying around for some reason (snake oil ahem).  Rebuilt his petcock and put a spare fresh gas cap gasket on it and fired it up.  Still rough around the edges but it's getting there.
