Let me start off by saying my last post I was very frustrated and lack the mindset to explain my problems.
I had a video of my clutch tear down and re-install. This video can not transfer or upload due my computer issues. So I have to say I installed all the parts correctly.
According to DIY instruction:
https://wrenchandspanner.wordpress.com/2014/12/20/how-to-change-and-adjust-a-clutch-sohc/Recap of my issues:
1. Why I took apart my clutch? The bike drove fine until it started to pop of gear second and 3rd on hard pulls.
2. I took apart my clutch 2 years ago to inspect any damage or apparent issues. I could not find any but once the clutch was taken apart it would not engage the clutch lever correctly or function properly once reinstalled.
3. Can not engage "Clutch Lever" by the Clutch case. This Clutch lever is adjusted correctly and became issue right after I took apart the Clutch to inspect any issues.
When taking apart the clutch I did not see any metal filings in the oil, broken parts or damaged clutch basket. All the parts, spline washer, clutch friction disc and clutch lifter plates was installed to Honda specs. I followed the DIY instruction above link. Plus I had the Honda CB750 manual as well.
4. When engaging the clutch lever it feels like the clutch lifter plate isn't depressing inside the clutch basket. I can see the Clutch case flexing instead of the proper engagement. It will not shift into gear with engine off, I tried shift into 1st gear and the neutral light is turned off letting me know it's in 1st gear but will spins freely and is not engage to the engine block.
Does anyone know what my problem is?
I have a spare cb750 clutch basket and gear in photos.
Is this problem an engine tear down?
Sent from my SM-A526U using Tapatalk
