Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Ok so just to help here, see if you can get a member to make some bolts out of hex , or studs out of rod.. They only got to know the length , and even if they cut only 85 % -of thread , you die will finish it easily. You just need to tell them length and maybe send material. 9/16 hex ought do it. You any want to safety wire them..
Measure the stripped hole, see if it's still ok for 9mm... if not 3/8 20 is yer ace in the hole..m
Blanks should be around .350 before threading.. 9 mm equals . 354.
Turn 10 mm orv3/8 down, they are fairly hard, if your die is carbon steel, it may not live long. .
Quote from: 754 on December 28, 2020, 04:10:47 PMBlanks should be around .350 before threading.. 9 mm equals . 354.Where can I find allen head bolt blanks to thread 9mm ?
