Author Topic: Winter/Spring lay-up work 2020/2021  (Read 4098 times)
Offline Kevin D
  • SE Michigan
« on: December 28, 2020, 08:12:34 AM »
This is my first project thread even though I have been a member here from the early days. I have had a great riding season this year even though the start was delayed due to lockdown. My day rides on my Honda was about the only recreational activity open to me in 2020 so I made the most of it. For 2021 I have a couple opportunities for next level riding: overnight travel to Ohio’s Windy Nine and a visit to Benellis in Ontario for a vintage MC party. Either trip will be hundreds, maybe 1000 miles. So, the CB at 91000 miles has to be in tiptop shape and as comfortable as possible for me.
 - I replaced the original rear shocks with Hagons several years back. They are fitted with 23kg springs and set at the minimum preload. It’s tolerable, but harsh. I’m working with Hagon GB to get a lesser spring. I have to fashion a spring compressor. I don’t have lathe mill drill press to make this kind of stuff.
 - At the front end, I have unusual tire wear, scalloping and off center. Maybe not unusual for BT45. I have had some input at the 20/100/2020 thread that others have noted this same type of wear, thanks guys. I try to run about 37/38psi, and not the 30psi? that was standard in 1970.
 - Also at the front end, I’m picking up some minimal kind of vibration through the handlebars:
B-d-d-d-d-d-smooooooth-B-d-d-d-d-d-smooooooth-B-d-d-d-d-d-smooooooth-    on a few seconds interval.
It happens even on expected smooth pavement. I have never done any upgrades on the front suspension, only the occasional fluid change with ATF, one time leaky seal replacement, and tapered roller bearings in the triple tree. I’m thinking I need more dampening, maybe new springs? A 1” preload spacer? emulators?
- I have a small fluid seep from the front brake piston that must be addressed. At the last brake service I got new pads, seal, phenolic piston, holding arm from godffrey, and it has been good for several years.  Prior to that I got a new seal and pads, reused original piston with minor rust divots and it was also good for several years until a seep began.
- My starter clutch is acting up just the tiniest bit. I have the roller/spring kit from Yamiya and a rotor puller, but not the $150? gear. I hope to refinish the chatter marks on the gear and avoid the $150? cost of a new gear.  It’s only occasional misbehavior, but it won’t get better without service, it will only get worse.
 Also have the oil seepage at the alternator wires. That seep might be stopped while I’m into the starter clutch.
- I have a K2 luggage rack to fit, it came without its hardware kit, and as my CB is a K1 the turn signals don’t have have the correct mount. I will be seeking some used parts here, new $100? ouch!
That’s most of it, a lot for me, probably not too much for all you builders. I have to start rounding up material. Anybody in US getting parts form Yamiya in a timely manner?
« Last Edit: April 23, 2021, 07:19:51 AM by Kevin D »
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Kevin D
  • SE Michigan
Re: Winter lay-up work 2020/2021
« Reply #1 on: December 28, 2020, 08:27:35 AM »
Tire wear 2020, scalloped and off center
Tire wear 2011, severely scalloped after 8000 miles
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
Offline StockRider
  • Sustaining SOHC/4
  • Well, I thought it was stock...
« Reply #2 on: December 28, 2020, 08:28:05 AM »
Ordered several small bits and pieces from Yamiya on 12/08, shipped on 12/08, and made it to Central Illinois, USA on 12/14 via UPS.
'70 CB750K0 - "Truck" | 4x4 | 4 Cables/4 Carbs/4 Cyls/4 Pipes | PO: "Old J.O.", a.k.a. Dad, Ride Free Brother!
Offline newday777
« Reply #3 on: December 28, 2020, 08:46:38 AM »
Tire scalloping also known as cupping is caused by a loose point in the steering bearing race, which is results of a dent in the race by hitting bumps. Replace the round ball steering bearings with tapered bearings, properly torqued with a torque wrench and castle nut socket.
When you change the fork oil, do you disassemble the forks and totally wash out the out gunk in the bottom? If not start there and replace the bushing.
There is a lot in play to give the action you mentioned of the forks. Different lengths in springs and spacers can give that to your ride(never assume that even new springs are the same length sent to you. You have to measure every thing.
Uneven fork oil levels also play into the fork action you mentioned. Use a fork oil suction tool to get equal oil levels nit just by liquid pouring in measurements.
https://www.motosport.com/product/?cc=us&gclsrc=ds>_Fork_and_Shock_Maintenance=>_Suspension_Parts_and_Accessories_=&key=Motion-Pro-Fork-Oil-Level-Gauge&product_id=MOP002G-X001-Y001&psreferrer=https://www.bing.com/&pssource=true&segment=badger&utm_campaign=Shopping+-+Dirt+Bike+Parts+-+B&utm_content=Dirt+Bike+Parts+&utm_medium=pla&utm_source=bing&utm_term=4580771602876218&variant=MOP002G-X001-Y001&variant[MOP002G]=MOP002G-X001-Y001
Stu
My current rides
Prior bikes....
Offline Kevin D
  • SE Michigan
« Reply #4 on: December 28, 2020, 01:59:30 PM »
Thanks for your input sirs.
It’s good to know that even with the holiday season+covid that Yamiya shipping is timely. Thanks StockRider.
newday, I have not been thorough with my fork oil changes, probably a flush until clean if nasty stuff came out. I haven’t yet started on this winter work so I don’t know what I will encounter. I hadn’t noted any kind of rattle in any of the front end parts. The guide bushing at the top of the fork tube is €38, not currently available 51451-319-000, but I have found the piston at CMSNL for €29, 51442-300-000P.
 The manual describes the piston and the lower case as the wear items in the front fork.
 The tapered roller bearings were installed (2007 61000mi) several years back, thoroughly lubed, properly snugged, but no follow up has been done.
 I have an old timey baby bottle used for fork oil filling and while I can’t say the quantity is exactly 7.0oz, I can say that both are equally filled.
I’m hoping that a fluid change/flush, bearing snug, spring tune/replace, new tire will take care of this.
Bushing
Piston
« Last Edit: December 28, 2020, 02:04:08 PM by Kevin D »
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
Offline Kevin D
  • SE Michigan
« Reply #5 on: January 13, 2021, 02:52:00 PM »
 I put the first wrench on my CB today, removing a rear shock for disassembly. I found a suitable and safe spring compressor in my garage, a 1” ratchet strap! It worked like a charm as the springs only needed 1/4” compression to remove the keepers. I’m not the first guy to use a ratchet strap, I found this using Google advanced search.
 I also noted a wear bar showing on my rear BT45, and since the front tire is also shot it’s might be time to switch brands. I have been using Bridgestones since putting my CB back on the road in 2002. The first set were Spitfires, and the rest have been BattleAx BT45’s. The Spitfires were available locally, but with a computer and a PayPal you can get whatever you want. I’m looking at ContiGo’s now, in the inch sizes, instead of the 120/90-18 and 100/90-19 that I have been using. Anybody using them?
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
« Reply #6 on: January 13, 2021, 03:16:28 PM »
 - At the front end, I have unusual tire wear, scalloping and off center. Maybe not unusual for BT45.  I try to run about 37/38psi, and not the 30psi? that was standard in 1970.
Hey Kevin...I recently noticed unusual tire wear on the front of my K4's BT45 as well.  A couple years back, I refreshed it with tapered bearings, new Progressive springs and of course fork oil. I run pressure 38psi.
My tire is at least 5-6 years old so I will just replace, but now you have me thinking why?
Subscribed to follow your progress.
Offline Kevin D
  • SE Michigan
« Reply #7 on: January 13, 2021, 06:02:52 PM »
Stev-o,
 I have had some input from Terry, who has given up on BT45’s due to this front tire wear. He is on many other forums and apparently this kind of front bt45 wear is not specific to CB750.
I’m looking at ContiGo, also Michelin Pilot Activ. Avon and Metzeler sold out.
« Last Edit: January 13, 2021, 06:09:06 PM by Kevin D »
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
« Reply #8 on: January 14, 2021, 06:49:13 AM »
Avon and Continental are both great tires, I run them on my Kawasakis.
Offline Kelly E
  • Geriatric Hooligan
« Reply #9 on: January 15, 2021, 06:19:01 PM »
Have you found a solution for the stiff spring issue. I have Hagon shocks on my 74' 550 and they are much too strong. I ordered the spring for a 150lb rider but my 250lb friend can hardly budge the rear suspension. It has been a couple of years since I bought them and I recently finished the bike only to find out that it's way too stiff to ride. Hagon told me to try the place I bought them (Dime City Cycles) instead of trying to help me figure out what springs I do need for their shocks.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Kevin D
  • SE Michigan
« Reply #10 on: January 15, 2021, 08:12:13 PM »
Yes Kelly, I have new springs on the way from UK, 20kg, to replace the 23 kg springs that came on the shocks. $125 shipped. I don’t know a thing about spring rates, but at $125 a pair, I hope the 20s will be good. When I bought these, I was expecting an occasional passenger and that got me the 23’s. I was told by Hagon that 20’s are standard for a 220lb rider. I asked about other spring rates but didn’t get any other info. Maybe there is something buried in the Hagon website.
 The ratchet strap worked very well to compress the spring and release the keepers, $12(?) for 4 at Harbor Freight.
The hardest part was lacing the strap correctly. The spring weight is marked on the end and 214mm is the unloaded spring length.
 I have never shopped at Dime City, do they offer alternate springs?
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
Offline Kevin D
  • SE Michigan
« Reply #11 on: January 15, 2021, 08:27:19 PM »
When we had Hagon USA (aka Dave Quinn),  Dave offered one free spring change if your new shock/spring combo was unsuitable. With shipping costs being what they are, I understand why Hagon UK doesn’t make that offer. Maybe Dime City will pick up that slack.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
Offline Kevin D
  • SE Michigan
« Reply #12 on: February 13, 2021, 05:27:50 AM »
It’s almost a month has passed since I made my material orders.
The tires and tubes showed up pronto.
The rear shock springs came almost as fast, from UK, but while they are lighter at 20kg vs 23kg and will fit the shock body, they are a wider diameter than the originals and the spring covers will not fit over them. If I use the wider springs I will give up the stock look, functionally ok but not what I want. I went to this vendor because their shocks perform well and resemble the originals. So after much correspondence I am patiently waiting for the correct springs to arrive.
The comprehensive parts order with 15 items, brakes sprockets gaskets lighting, was being held as one of the 15 items is back ordered. But more correspondence and maybe I’ll get 14/15 soon.
So I’m sitting here watching it snow 17f, 2-4” today, 6-12” midweek and 0f in the forecast.
The most important thing from Moderna was received early February so I am counting my blessings.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
Offline Kevin D
  • SE Michigan
« Reply #13 on: February 22, 2021, 04:43:39 PM »
Finally... my 14/15 parts order from DSS showed up Saturday 2/20. The front sprocket will be along sometime soon.
The 20kg slimline chrome shock springs showed up today 2/22 from British Cycle Supply in Wolfville, Nova Scotia. They also have a big warehouse in Limestone, Maine to service the US customers. I’d not been aware of their business but if you’re a Triumph/BSA/Norton owner, I’d bet that you know them. They have a terrific customer bike gallery that’s about to get a submission from me..... and they are a Hagon dealer. I probably would have been way ahead if I had started at British Cycle Supply and not Hagon UK.        http://www.britcycle.com/
So, I have most all of my parts and a few days to begin the work. The garage is unheated but it will be a bit warmer this week with highs in the 40’s and no more single digit lows.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
« Reply #14 on: February 23, 2021, 02:54:47 AM »
Following  ;D
Offline Kevin D
  • SE Michigan
« Reply #15 on: February 24, 2021, 09:07:47 PM »
I found this video of the unique Norton Transformer amongst the customer bike photos posted at British Cycle Supply.
http://www.britcycle.com/Bikes/customer/JoeW_Nor_Transformer.htm
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
Offline Kevin D
  • SE Michigan
« Reply #16 on: February 25, 2021, 02:30:16 PM »
My first task was completed yesterday. I loaded the 20 kg springs onto the Hagon shocks. There are new upper bushings at the upper shock mounts. I still need to disconnect the shocks, exercise and lube the HondaMan swing arm bushings.
The ratchet strap spring compressor did the job.
« Last Edit: February 25, 2021, 02:34:49 PM by Kevin D »
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
Offline Kevin D
  • SE Michigan
« Reply #17 on: February 26, 2021, 04:14:35 AM »
I pulled the rear wheel off yesterday and replaced the sprocket and brake shoes. The old sprocket is original with 91000 miles and is showing wear. Not too badly but, it’s time. New front sprocket is on back order for now. Both sprockets are aftermarket. I hope that works out OK and it takes another 50 years to wear them out haha. The front has been replaced twice and flipped twice. The rear sprocket is stepped can’t be flipped because of the offset. I’m staying with 18/48 ratio. If I did more in town riding I might go for 17/48 but I like my 48mpg and don’t want to mess with that. The Diamond chain is in good shape.
I also replaced the brake shoes. I was running out of adjustment and it seemed like a good time since I was in there. It looks like about .040” worn from the old shoes. These are also aftermarket and one of the shoes gave me trouble at reassembly: it wouldn’t fit over the pin. 10 minutes with a round file corrected that and I hope and expect it won’t be any further problem. A stuck brake shoe would not make for a fun afternoon of riding.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
Offline Kevin D
  • SE Michigan
« Reply #18 on: February 26, 2021, 04:38:46 AM »
I have been fitting the rack and signals. It’s not quite a done deal but I have all the hardware on hand and the turn signals are fitted to the rack. As the rack is for a K2, I needed to get the long bolts and the make the necessary spacers for the rear mounting. The turn signal location is about 6” wider 3” higher 6” back from stock. I hope that works out OK.
Prokop, I need to find your link to the waterproof bags. Are you happy with them?
The new TL lens came with a dried up old DOT sticker attached. I soaked it WD40 for an hour, heated it, and still managed to scratch the new lens. It’s a good thing I’m not a heart surgeon.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
Offline Kevin D
  • SE Michigan
« Reply #19 on: February 26, 2021, 04:42:40 AM »
Today’s challenge. Off with the BT45. On with the Conti.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
« Reply #20 on: February 26, 2021, 06:22:14 AM »
Good luck!  I think you will run the Conti's, I run them on my Kawasakis...
« Reply #21 on: February 26, 2021, 07:23:07 AM »
Here you go:
https://www.amazon.com/gp/product/B089ZZRPXL/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
Great bags, you can haul a lot in them.  Roll top keeps them dry too.
Offline Kevin D
  • SE Michigan
« Reply #22 on: February 26, 2021, 09:17:57 AM »
Halfway done... the easy half. A long time ago I did this job with the 8” irons on a regular basis. Now I’m struggling with the 16” tools.
I found this sticker on the tire: 3 years flat tire towing, 150 miles. I hope I never have to use it.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
Offline Kevin D
  • SE Michigan
« Reply #23 on: February 26, 2021, 09:24:15 AM »
Prokop, thanks for the link. I saw a larger top bag as well that might make a nice backrest. It looks as if it would leave the rack empty for a top box.
Stev-o what pressures do you run? How many miles do you get out of them?
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
« Reply #24 on: February 26, 2021, 09:35:11 AM »
Too easy to pinch a tube when mounting the tire by yourself.
Really important to have tire irons without sharp corners and have a little bit air in tube when wrestling on the half last part of tire.
Tire must be richly lubed with tire lube where in contact with rim. Both sides of tire.
It glide nicely on without a hard fight when irons can pinch the tube.
I learned the hard way. I pinched some tubes the last years. Luckely not stranded away from my garage.
One flat happened 1 1/2 year after.
I saw the bite marks after the tire iron I later shaped rounder on a bench grinder.
I'll grind it smoother where it can hit rim. Surface has a molded not perfecly smooth surface.
Rim protector is not always that cooperative.
Always have extra of new tubes.
