Author Topic: K0 CB750  (Read 1052 times)
Offline Thomsodm
K0 CB750
« on: January 03, 2021, 02:58:26 PM »
Have just started to replace a wiring harness, and having taken apart the left handlebar control a small brass colored spring about 3/16 - 1/4 inch long fell out.  I have the spring but cannot see a spot for it.  There is also a small C shaped conductor that goes into the white plastic piece the turn signal lever moves but as that also fell out I can't tell if it goes into the white plastic piece in a concave or convex orientation.  Anyone have any idea?
Re: K0 CB750
« Reply #1 on: January 03, 2021, 03:27:35 PM »
I think a ball goes on the spring, which sits in a hole , holds switch in position between left and right.
 The contact should have 2 shiny spots where it makes contact,  sliding in place,,
 Good Luck and Welcome..
