Author Topic: New hookup on m-unit blue, getting emergency flashers instead of turn signals  (Read 1875 times)
Offline ralt12
Wiring up the m-unit blue for the first time, using Messner Moto’s switches. When I connect the unit to power, indicators (front and rear) come on (like I believe they are supposed to). Headlight comes on with a press of the button, and another press toggles high beam. Horn works. My hang up here is turn signals. Regardless of whether I press left or right, I get emergency flashers. Disconnected the right signal input, still the same. Reconnected the right input, disconnected the left, still emergency flashers.
Both indicator lights are on in the instrument, but I don’t know if that’s because they’re on as daytime running lights.
Any ideas as to whether I’ve fouled this up or is it a bad m-unit ?
Offline ralt12
Thanks for pointing me in what seems to be the right direction; the m-unit app was having a hard time recognizing that my account was my account, and changing my password on the phone wasn't working. I was successful on the iPad. So now I have updated firmware and when I bleed the brakes I can start the setup process.
Programmed for the A button.
Thanks so much.
« Last Edit: January 11, 2021, 11:29:53 AM by ralt12 »
Offline ralt12
First fix--had neglected the diodes for the turn signal indicators, which caused feedback though the turn signal system.
