Author Topic: Zinc!?  (Read 757 times)
Offline TurtleSnifferII
Zinc!?
« on: January 14, 2021, 12:01:31 PM »
I remember reading on here that is a good idea to use zinc but I had forgot. Recently the local auto store started carrying the “zddp” so I bought some. Question is how much should I to put in a 1980 cb650 running 20w-50?
Thanks
Offline goodtryer
Re: Zinc!?
« Reply #1 on: January 14, 2021, 12:08:15 PM »
The bottle I had said the amount to put per liter or quart. Check the label on the back.
But before you do that, make sure the product you have is the one for wet clutches. At the time I bought mine(been a while), there were 2 versions, one that specifically said, "not for use in wet clutches" or something to that effect.
Cheers
"Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles."
-Dostoievski
1977 CB550K
1978 CB750K
1973 CB500K
Re: Zinc!?
« Reply #2 on: January 14, 2021, 12:13:14 PM »
Some additives contains antifriction stuff too. Not good for wet clutches.
In a car no problem.
There are several recent threads about motorcycle oils that have more zinc och phosphorous. Just search with any search engine. Sohc forums + ........
Not for the modern bikes with Catalytic converters that use oils with less.
« Last Edit: January 14, 2021, 09:33:18 PM by PeWe »
Offline 69cb750
Re: Zinc!?
« Reply #3 on: January 14, 2021, 01:22:30 PM »
None.
