Author Topic: Do drive chain 'Half-links' still exist? I want to add only one link to an RK  (Read 648 times)
Offline grcamna2
I remember when i was a kid and they sold 'half-links' for mini-bikes,and found out later they sold them for motorcycles.I haven't heard anything about it lately,although I'm familiar with the Grainger company 'back in the day' and they advertised them regularly in their catalog for slow speed,Industrial drive chains..
I have installed a different,longer swingarm from another model and would like to shorten the chain just one link if possible:it's an RK drive chain.
Offline BenelliSEI
  • 1969 cb750
Never heard of these. If anyone has info, please include a photo!
Offline rb550four
  I have used half links on my snowbike, I purchased mine at a tractor store. a New Holland Tractor store . I suppose that any  tractor supply would have one.
Offline simon#42
  • liverpool
dont do it !  they are dreadful things and are very weak , thats why you dont see them anymore
Half-links aren't as strong as normal links.
edit, Simon beat me to it. They are still available as far as I know.
Cant you just run it a while , then take full link out ?
Offline Tim2005
They aren't very good things, but I have run one on a trials bike before, though it wasn't exactly stressed on that.  If you are still keen on one you might have more success searching for "cranked" link, as that's the other name for them.
Offline kmb69
Offline grcamna2
Oh yeah,I can do that.
Offline Rookster
Late 70s Triumph Bonnevilles used a 530 chain with a half link.  You should be able to find them at any British motorcycle parts places.  The issue is you end up with essentially 2 master links: One to connect the half link to the chain and another removable pin to connect the other side.  A 750 Bonneville has about the same acceleration as a CB750 until you get over 75-80 mph.
Scott
Offline onepieceatatime
I'm pretty sure I have one in my garage. It came packaged with a master link.
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline 333
  • Time for change
A chain and sprocket set have a limited life, usually 10k to 15k depending on how hard you are on it. A new set may take up the slack you have.
And always change chain and sprockets together. They wear at the same rate, and if you do one without the other, you'll be lucky to get 1k out of it.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
