Author Topic: swingarm  (Read 1257 times)
Offline Randy Nevrotski
  • Randy
  • ITS AUTO-MAD-TIC
swingarm
« on: January 17, 2021, 08:39:50 AM »
What aluminum swing arm will bolt up /line up the easiest  without modify CB750A Frame Also what front end will work. I cant find where i saw it I believe i could use a Katana swingarm and a GSXR front end is that correct . what years parts would work or what could i use . I want maching rims . its just an idea I'm looking into.  on a rear disk brakes could i put a hand leaver for that because 750A doesn't have anything on left side handle bar side
1976 CB750A & Other bikes 1980 KZ 650 cafe racer  81 CM400A 82 GS450 79 KZ650 84 NIGHTHAWK 700 77 KZ650 CAFE  87 ZX750R NINJA 2001 KATANA 600 1983 GPz 750 1980 CB750 CUSTOM Past bikes 1974 suzuki GT750 TRIPLE Care Free Custom chopper 117 motor 95 Honda XR650L Dual Sport 87 ZX600R NINJA Honda CB550FOUR 87 Yamaha 225 trike honda 250R trike RM80 HONDA TRAIL CT70
Offline ebrown0104
Re: swingarm
« Reply #1 on: January 19, 2021, 05:57:07 PM »
Cognitomoto.com can make you a set of triple trees for just about any front end.  You just tell them what you have and give them a bunch of money.  For rear disc brakes you can use an F model rear master cylinder assembly, just remember you'll lose the parking brake
Re: swingarm
« Reply #2 on: July 10, 2021, 01:50:52 PM »
 I'm late to answer but a gs1100E with dual shocks seems to work on cb750's,  it's longer though. Shock spacing is probably an issue.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
Re: swingarm
« Reply #3 on: July 10, 2021, 02:16:00 PM »
You need to add shock mounts if you use a katana swingarm, and switch stems on a gsxr front end, and change the fork stops. The offset is different on the front end so it may take you a bit to adjust. The katana swingarm is also longer. I don’t remember for sure, but  in the 4-6” range. I think I have both a katana swingarm and gsxr frontend under my bed. Hit me up if you want to go that route.
