Author Topic: Bike from scrapyard Saudi  (Read 22023 times)
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
Re: Bike from scrapyard Saudi
« Reply #175 on: June 28, 2023, 11:02:44 AM »
Thank you Andy.
I’ve ordered the battery now, I only made enough room in the battery box for an 12v 12ah one, as I originally didn’t install the starter motor.  The battery is an AGM type which you add the acid to, then charge, I’m mounting it sideways so hopefully it will not leak. I also need to install indicators to the fairing somehow. The wrong mirrors arrived so still chasing them.
Offline Gamma
« Reply #176 on: July 01, 2023, 03:27:14 AM »
I built the battery tray to fit a specific size of AGM battery, believing that you can install these on their sides.
So I filled with acid, charged it and sealed it with the supplied bungs.
I removed the label so that I can install it on end.😂
It should not leak, at least that is what I am hoping.
Anyone out there done the same?
Offline C317414
« Reply #177 on: July 02, 2023, 01:27:39 PM »
I would not do it.  Varta has very specific instructions that lead me to believe that these are not true AGM batteries:
https://www.varta-automotive.com/en-nz/varta-battery-support/battery-basics/fitment-and-filling-batteries
Offline Gamma
« Reply #178 on: July 04, 2023, 08:22:18 AM »
Thanks for your thoughts on it, I’ve gone ahead and installed it for now.  I filled it with acid, waited two hours, then gave it an initial charge and then installed the blanking caps.
I left it over night on end, and now it’s fitted.
I’ll let you know if it leaks.
judging by many comments on the web, it should not leak if the caps are installed correctly.
Meanwhile I will look for a Gel battery that might fit
« Reply #179 on: July 04, 2023, 08:56:27 AM »
I’m really not a fan of the Gel batteries. Regular AGM are far more reliable
Offline Gamma
« Reply #180 on: July 04, 2023, 11:48:01 AM »
Yes, I believe AGM are better too. It’s still not leaking. But there again I’ve not fired the engine up yet
Offline Gamma
« Reply #181 on: July 12, 2023, 09:24:09 AM »
I’ve installed the battery, no leaks yet.
Working on fitting front indicators, I’ve made brackets to fibre glass inside the fairing
I still need to get some foam to make the seat
And am still waiting for foam socks to go over my carb intake venturis
And now a question for the wise ones on this forum
I put the engine together in about 2008, I used assembly lube and engine oil.  But as she’s been sat for so long, I’m considering putting a thimble full of diesel down the bores to help lubricate the bores and rings for initial turnover on the starter.  I intend to remove the plugs and turn on the starter to get oil around the engine whilst looking through the cam cover holes.  Anyone think that I should also squirt a bit of oil onto the valve train?
I’m also going to check the valve clearances are at .004” as per Webcam instructions
Offline Gamma
« Reply #182 on: July 16, 2023, 01:47:30 AM »
Indicators now fitted.
Getting very close to starting her for the first time.
I put a very small squirt of diesel mixed with stroke oil in the bores and turned her on the starter, oil light went out after a few short bursts 😀
Offline grcamna2
« Reply #183 on: July 16, 2023, 02:05:22 AM »
I like that fairing  8)
Offline Shtonecb500
    • Youtube profile
« Reply #184 on: July 16, 2023, 05:35:15 AM »
super clean
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline Gamma
« Reply #185 on: September 15, 2023, 06:28:29 AM »
Thanks to all the information received from you guys over the years and Mike Rieck’s headwork and APE and Dynoman for parts.  It runs today for the first time
« Last Edit: September 18, 2023, 02:35:12 PM by Gamma »
« Reply #186 on: September 15, 2023, 06:58:19 AM »
Looks and sounds great! Nice job.
What else is needed to get it on the road?
Offline Gamma
« Reply #187 on: September 15, 2023, 09:16:38 AM »
Thank you, I next need to fit the fairing which is ready but unpainted, then cut the end of the bars back and fit end caps.
I also need to add a brake switch for the rear brake.
Then try and get it matriculated here in Spain.  Unfortunately I have no paperwork for it 😬
« Reply #188 on: September 15, 2023, 09:34:00 AM »
Looks good, sounds good and must smell good too! ;)
Which cam?
Offline Gamma
« Reply #189 on: September 15, 2023, 11:34:44 AM »
Yes, PeWe, no leaks yet.
Cam is Webcam 63a. Valve clearances set at 0.004” for inlets and exhaust. 836 bore by APE. Stage 2 head by Mike Rieck.  Dynoman Heavy duty studs, head and crank.  Dyna 3 ohm coils and leads with Mark Paris resistors. Iridium DR8EX plugs set at .7mm gap.  NGK plug caps with resistors removed.  New points at the moment but I have Dyna S ignition to fit.  Heavy duty cam chain. Original cam chain guide and roller which I examined when I built the engine in 2007, so fingers crossed.  CR29 carbs using velocity stacks and socks.  Starting point is Mains 120, Slow jets 60, Needle in position 4, Airjet 240 and starter jet is 40
MotoGPwerks exhaust.
« Reply #190 on: September 15, 2023, 12:33:01 PM »
A recipe for success!
Offline Shtonecb500
    • Youtube profile
« Reply #191 on: September 18, 2023, 09:55:42 PM »
sick
Online BenelliSEI
  • 1969 cb750
« Reply #192 on: September 27, 2023, 01:39:51 PM »
Sounds amazing and looks even better! Congratulations!
Offline denward17
« Reply #193 on: September 27, 2023, 07:10:43 PM »
Sounds great, Love the AFR guage....
Offline newday777
« Reply #194 on: September 28, 2023, 02:03:32 AM »
That does sound sweet! That will be a fun ride with your setup. Lots of good parts in it.
Stu
My current rides
Prior bikes....
Offline Gamma
« Reply #195 on: October 05, 2023, 09:44:05 AM »
Thanks guys
« Reply #196 on: October 05, 2023, 01:51:49 PM »
Sounds great! I hope your titling it goes smoothly without any major headaches.
Offline Gamma
« Reply #197 on: December 12, 2023, 08:54:31 AM »
Put my 40 year old vacuum gauges on the CR29’s today. I think number 3 needs tweaking a little
Offline newday777
« Reply #198 on: December 12, 2023, 09:10:36 AM »
The rpms are high and hanging some
Stu
My current rides
Prior bikes....
Offline Gamma
« Reply #199 on: December 12, 2023, 09:26:28 AM »
Yes, you are correct, it’s very early running stages, also got to keep the rpm up on the new cam.
But I’m generally very happy with the progress so far. No nasty leaks, bad noises or smoke as of yet😃
