Author Topic: Bike from scrapyard Saudi  (Read 21547 times)
Re: Bike from scrapyard Saudi
« Reply #200 on: December 13, 2023, 08:36:37 AM »
The motor sounds awesome!
What else is need before a test ride?
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
« Reply #201 on: December 13, 2023, 02:55:36 PM »
Thanks Stev-o
Next I plan to balance the carbs a little.  I spent quite a time on YouTube etc: trying to find out how the CR carb adjusters for this work.  Luckily I came across Mike Reicks video which explains this.  Unfortunately I’d already tentatively loosened the nut (which is actually the adjuster) and not the centre screw on one of the carbs 😬 I’ve now double checked what I’m doing so I don’t bugger it up😃
I can’t really use the bike on the road as yet, as I have no papers for her and will have to try and matriculate her which won’t be easy. But needless to say I need to check that she is running reasonably well carbs wise and take her for a quick spin around the estate to check she goes through the gears and is safe for inspection.
Offline Nightshift
  • Semi-elderly
« Reply #202 on: December 14, 2023, 05:36:41 PM »
So I checked out the CR29 carbs to see what jets are installed etc: so that I have a known starting point.  Mains were 120 and slow jets 60, needle clips in 4, as per spec. Air jets are 240, standard spec is 250. Starter jet is 40, standard is 45.  From what I’ve read about that, 40 is better.  I then statically balanced them.
Then installed them and am now working on making barbs, so I can balance them
Wow that is really creative. I'm gonna make a set of those barbs as well for mine. Very slick! Bill
Can someone update me a what's offensive today? It's really hard to keep up!
Offline Gamma
« Reply #203 on: December 15, 2023, 02:19:18 PM »
Offline Nightshift
  • Semi-elderly
« Reply #204 on: December 15, 2023, 02:49:13 PM »
The barbs work well😄
Sweet. Just one question for you guys with 4 vacuum gauge setups for tuning ... how do you know the gauges are calibrated to each other before you start? I was thinking I would just use 1 gauge on a 4-port manifold with ball valves on each so I can read the vacuum on each cylinder individually to eliminate this unknown. Cheers, Bill
Offline Gamma
« Reply #205 on: December 15, 2023, 03:20:35 PM »
My gauges are very old, about 40 years, and I haven’t balanced carbs for about the same time.  I did swop them around between carbs whilst doing the balance to check that they were reading correctly.  But I think one gauge and selecting each carb in turn would be fine.  I’m sure that others with more recent experience would be able to advise
Offline BigAl
« Reply #206 on: December 15, 2023, 07:10:12 PM »
Wow Gamma, just perused your build, great story and great looking project.
1978 CB550K4
Offline Gamma
« Reply #207 on: December 16, 2023, 11:49:46 AM »
Thank you BigAl😃
Offline BenelliSEI
  • 1969 cb750
« Reply #208 on: December 19, 2023, 05:03:40 AM »
Bill…… my old Motion Pro instructions recommend calibration before every use. I set them up as usual but tie the 4 hoses to a multi barbed connector. Then use a single line to connect it to one vacuum nipple on an intake port. Start the bike and using the equalizing valve (small needle valves on my unit) adjust so every gauge reads the same. Pull them off the multi connector, attach to 4 intakes and start adjusting carbs.
« Last Edit: December 19, 2023, 11:25:05 AM by BenelliSEI »
Offline Nightshift
  • Semi-elderly
« Reply #209 on: December 19, 2023, 05:19:22 AM »
Bill…… my old Motion Pro instructions recommend calibration before every use. I set them up as usual but tie the 4 hoses to a multi barbed connector. Then use a single line to connect it to one vacuum nipple on an intake port. Start the bike and using the equalizing valve (small needle valves on my unit) adjust so every gauge reads the same. Pull them off the multi connector, attach to 4 intakes and start adjusting.
John that makes sense. I was thinking 1 gauge with a 4-port manifold would definately be accurate, but a PITA when calibrating the carbs. Your method is better I think. Cheers, Bill
Offline BenelliSEI
  • 1969 cb750
« Reply #210 on: December 19, 2023, 11:27:19 AM »
Bill…. I’ve also noticed that quite often when you adjust one carb, the one next door can change. It helps to see all four at the same time.
« Reply #211 on: December 19, 2023, 08:23:28 PM »
Especially 3 & 4 for me
Offline Ley.Alexander
« Reply #212 on: June 09, 2024, 10:57:09 PM »
Very nice build! I wonder if you come any further with the jetting? I have CR29on my stock 650 engine with 4-1 exhaust. My starting point for the jetting seems very rich. I’m looking for a better starting point for the jetting.
My jets now:
120 mains, 62 pilots, YY8 needles, 2.5 slides, and 250 main airs.
Thanks in advance!
Offline Gamma
« Reply #213 on: August 14, 2024, 10:51:31 AM »
Not got any further yet. Been busy with other projects and family.  Hope to restart in a couple
 of months
