Author Topic: CB750 - indentifying cylinder assembly version?  (Read 517 times)
Offline flybackwards
« on: January 25, 2021, 12:20:58 PM »
Let me ask this another way - there are several version numbers on the block assemblies all based on 12100-300-  there's at least 020 030 040 050 and 060 versions - I need to replace an 060 on my K7 - is there any casting numer or other id?  Or what are the key visual differences? Is there a reference somewhere?
Re: CB750 - indentifying cylinder assembly version?
« Reply #1 on: January 25, 2021, 01:17:13 PM »
 Early ones have different shaped holes in the bottom for oil drain?
But I think 69 to 77 K should all interchange,  the ones that won't work are F model versions.
« Reply #2 on: January 26, 2021, 10:29:58 AM »
 I forgot there is differences in the oil hold rubbers , some have bigger holes with the rubber over a dowel.
 I think 73 or 74 should all fit to the end .. so get that  same style to match your head.
