Author Topic: racing cb500 marching on  (Read 19044 times)
Offline turboguzzi
Re: racing cb500 marching on
« Reply #25 on: February 26, 2007, 03:20:53 PM »
OK peter, here's the deal
I have cast a pair of each.... share with me all your CB500 secrets and you get a set.
Fair enough?
Think twice before accepting. I have a VERY long list of questions :-)
TG
Offline jt
« Reply #26 on: February 27, 2007, 05:17:49 AM »
Hi yossef,
We don't use nova in the 500.The 250/350 K4 gearbox fit straight in. In the Uk these cost about £800 and use some of the existing gears,works well at half the cost of a nova. Regards
Peter c
Peter,
    Could you go into a little detail on this? Do you use the complete 250/350 gearbox (shafts & all)  and some of the 500 gears? ???
Thanks
JT
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #27 on: February 27, 2007, 06:27:40 AM »
Hi yossef,
Peter c
Peter,
Thanks
JT
             Yeah Peter, I'm with JT, I would like to hear more on this subject also. Would that setup be better in a 550 also? ??? Details Please.
                                                  Later on, Bill :) ;)
Member # 1969
peter c
« Reply #28 on: February 27, 2007, 09:16:03 AM »
OK Guys,
If you get a set of gears to bring the ratios closer and give also a higher first gear from a supplier in the uk what you get is a new main shaft,the one the clutch fits on, new gears for this shaft and you use standard 350 gears to make up the box,fairly simple and no engineering. The 550 and also some of the late 500s have a thinner 5th gear,the one at the sprocket end of the shaft because the 550 hase a direct oil feed to this bearing,also on a 550 you would need to use the clutch actuation on the sprocket end of the shaft. There are hundreds of these boxes in use over here,much cheaper than a full nova box.I Have personally used this setup in my 500 for 3 years and used the same on my two 350s in the past.Hope this is of some help.I must say for racing it's the best tuning going,increases lap times a lot.
You will need to use the 350 clutch centre as the splines are different.
I may have some tuning secrets but only by private email.
Peter c
« Last Edit: February 27, 2007, 09:43:08 AM by peter c »
Offline bill440cars
« Reply #29 on: February 27, 2007, 09:47:02 AM »
       Hey Peter,
               You've got an email enroute, as we speak.
                                                 Thanks, Bill :) ;)
Member # 1969
peter c
« Reply #30 on: February 27, 2007, 12:41:14 PM »
Hi Guys
For those who want a better rear brake we used a cb77 unit fitted the other way round to a cb77 with a modified brake plate,gives a lighter and more efficient twin leader.
peter c
Offline turboguzzi
« Reply #31 on: February 27, 2007, 01:12:07 PM »
Hi pete
I am planning to fit a CB350/400 hub like the one in the pic. it's the italian classic bike champion's bike by the way.
In any case, at least here in italy, CB77's (hubs included :-)) are very rare on the ground
should pick a whole CB350 wheel this weekend
TG
Offline faux fiddy
  • bike in a box
« Reply #32 on: December 18, 2014, 04:31:01 PM »
bump
3,000th read.
This thread was favorited on this computer, so it's my  portal to the website.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
« Reply #33 on: December 19, 2014, 06:47:00 AM »
TG started several threads as time went along, this is but one. His experimentation in the name of making it faster was inspiration for me too.
Offline SoyBoySigh
« Reply #34 on: August 04, 2015, 06:15:56 PM »
Yeah - BUMP - I agree, some interesting stuff, and pic links that are still viable!!!
-Sigh.
