Author Topic: Lets talk about my bung hole  (Read 839 times)
Offline y2kc0wb0y
  • B00msh0cka
  • Shoot the pickle....
« on: February 03, 2021, 05:39:38 AM »
Anyone successfully adapt the M16 x 1.5 male bung to a 1/4 inch female? I want to move away from the $h1tty cheap Cb550 petcocks and try to use a Pingel. #madeyoulook
CB750K3 890cc| 2004 VFR800A| 76 CB550F| 77 CB750F| 73 CB350G| 79 XLH| 2007 BMW R1200GS| CB750K2
Offline ACK777
Re: Lets talk about my bung hole
« Reply #1 on: February 03, 2021, 11:15:51 AM »
I had found a really nice low profile German made steel adaptor off of one of those industrial lego sites a while ago but this was all I could find at the moment:
https://phenixindustries.com/product/metric-to-pipe-reducer-bushings-m16-x-1-50-1-4-npt-4/
And was going to pair it with something like this:
https://www.denniskirk.com/pingel/power-flo-fuel-valve-with-1-4-in-npt-inlet-6111-ah.p185249.prd/185249.sku?utm_source=google&utm_medium=csecid=6821162156&aid=76472566741&keyword=829654786293%3A%3Apla-829654786293&kid=829654786293&gclid=CjwKCAiAsOmABhAwEiwAEBR0ZvMQL-KJ7Sd95rLWSLx_e2wPScXJWOZNR__3hnJuh1KBHfndy7-B2xoCsU4QAvD_BwE
I was going to do the same thing but never got around to it but would love to see how it works out!
« Last Edit: February 03, 2021, 12:39:46 PM by ACK777 »
« Reply #2 on: February 03, 2021, 12:08:22 PM »
I would be able to make a few in near future, just getting my lathe going again.
 3/8 NPT is more common on petcock, lots of  used Pingel's on  ebay, come in single and dual outlet. Not sure if the screen will fit in the tank hole.
 I have made them before for 750 F tank, not sure what thread they were.
« Reply #3 on: February 03, 2021, 04:54:25 PM »
Offline y2kc0wb0y
  • B00msh0cka
« Reply #4 on: February 03, 2021, 07:33:16 PM »
Thanks Frank - this is the one I was attracted to. They make female adapter at 22M if that might be easier to step up. IDK...
http://www.pingelonline.com/motorcycle-fuel-valves/6111-ah.asp
« Reply #5 on: February 03, 2021, 08:08:15 PM »
I am thinking now that the 1/4 npt , will mean screen will fit thru the tank bung... probably  flow more than you need.
Offline y2kc0wb0y
  • B00msh0cka
« Reply #6 on: February 04, 2021, 03:14:35 AM »
Yes probably out perform everything Honda ever made.
Was originally thinking of getting a end cap and just drilling and tapping but I don't think there will be enough material to form good threads for the npt fuel valve. it would probably work but you'd want to stay to good roads as to not rattle it around much. :|
