Author Topic: Early Sandcast Found......  (Read 101224 times)
Re: Early Sandcast Found......
« Reply #1025 on: April 06, 2024, 11:44:37 PM »
Look very good, John!
You can use that with future tanks when you have got the dent bending skill ;)
Offline BenelliSEI
  • 1969 cb750
« Reply #1026 on: April 07, 2024, 05:23:16 AM »
Thanks! It’s kind of evolved from the material I had lying around!
Offline BenelliSEI
  • 1969 cb750
« Reply #1027 on: April 07, 2024, 02:02:51 PM »
Finished up hold down fixture today. The rear clamping mechanism was a bit of a challenge, but it turned out OK. The whole thing was such a mish/mash of scrap bits that I finished it off with a coat of black (hides a lot of evil) paint! Photos tomorrow and then the tank goes off to the “Dent Doctor”.
Next item will be to get all the engine covers of to the polisher. The weather is quickly becoming nice enough to get the engine painted. I do this outside, so need a nice day.
« Last Edit: April 07, 2024, 02:33:09 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #1028 on: April 07, 2024, 02:05:43 PM »
Per….the “throat” of the Sandcast “wrinkle tank” must be a lot narrower than the later models. When I tried a cb750K1 tank on the centre wedge piece, it slides right back over it. I’ll need to cut a new piece for that if I want to mount the later ones.
« Reply #1029 on: April 07, 2024, 09:31:01 PM »
In a word, yes: the tanks got wider and lower in the 3/71 'Kaizen' of the K1 series. It wasn't published much, but we noticed right away when we sat on the newer bikes: you couldn't see very much of the engine when you sat on the new bikes. The tanks blocked the view: you could read the "SOHC" casting letters on top of the cam covers on the earlier bikes, but not after that.
Offline BenelliSEI
  • 1969 cb750
« Reply #1030 on: April 08, 2024, 06:50:33 AM »
Completed wrinkle tank “hold down” fixture. Turned out pretty well.
« Last Edit: April 08, 2024, 09:15:58 AM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #1031 on: April 08, 2024, 06:52:12 AM »
The tank is pushed forward, tightly on a 1.5” high, large centre wedge block and then clamped at both ends. There is a “fin” underneath (full length 2x4” lumber glued and screwed) that can be clamped in a vice or WorkMate style bench.
The back end is a 2 X 4” with a 1/4” ply centre bit glued in. The tank strap bracket sits in it solidly. The top clamp piece screws down hard and really fastens down that end.
« Last Edit: April 08, 2024, 09:19:44 AM by BenelliSEI »
Offline grcamna2
« Reply #1032 on: April 08, 2024, 07:24:44 AM »
John,the right/rear of your tank looks like the seat pan was rubbing hard into the tank  :o
Offline newday777
« Reply #1033 on: April 08, 2024, 08:36:18 AM »
Might have happened after the original foam in the seat degraded and the slop in the seat cover started rubbing the tank with movement on the seat by the rider hitting the twisties!
Stu
My current rides
Prior bikes....
« Reply #1034 on: April 08, 2024, 08:38:31 AM »
This gives me some idea's.   have been mulling over the idea of picking up some paintless hammers and stuff and getting started on the practice needed.  Building that hold down is the hardest part of getting started.
Offline BenelliSEI
  • 1969 cb750
« Reply #1035 on: April 08, 2024, 08:57:50 AM »
Yes….. has some “patina” for sure. Determined to leave all the original paint finish.
Offline BenelliSEI
  • 1969 cb750
« Reply #1036 on: April 08, 2024, 09:00:04 AM »
Go for it! It took a few days, but really clamps it solidly.
« Last Edit: April 08, 2024, 10:40:41 AM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #1037 on: April 08, 2024, 09:05:45 AM »
Vapour blasted covers, packed and ready for the polisher. Includes the very early “nine hole clutch cover”. Headed there tomorrow.
Bead blasting the original seat pan next. It’s a much heavier gauge steel than later bikes. As a result, I didn’t break a single one of the sharp little tabs that retain the cover (so far!).
« Last Edit: April 08, 2024, 10:41:35 AM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #1038 on: April 12, 2024, 02:56:13 PM »
Finished cleaning the motor. Have to tape up some old covers and it’s ready for paint. The weather has to warm up a bit and stop raining. I want to paint outside!
Offline denward17
« Reply #1039 on: April 12, 2024, 03:07:42 PM »
John, you are a busy man!
Waiting on some decent weather for painting outside myself, nice today but very windy.
Offline grcamna2
« Reply #1040 on: April 12, 2024, 03:27:27 PM »
I can relate to that..  Wind  :o ::) .
The stuff never seems to quit out here.
I want to finish clear my tank w/ 2K clear.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #1041 on: April 12, 2024, 06:41:17 PM »
Davis is getting a lot of rain? Wow, I don’t recall it being particularly wet when I lived there.  (2000 to 2007)
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline grcamna2
« Reply #1042 on: April 12, 2024, 07:28:41 PM »
Yeah man  ::) :(  I Need more dry weather;I've got bikes to work-on and ride.  :)
« Last Edit: April 12, 2024, 08:07:14 PM by grcamna2 »
Offline BenelliSEI
  • 1969 cb750
« Reply #1043 on: April 12, 2024, 07:40:01 PM »
Den…. I have a deadline for this one now and we start racing in two weeks. Need to keep moving ahead!
« Reply #1044 on: April 13, 2024, 12:07:52 AM »
Wet weather is no insects nor  dust.
A party tent or a simple tarp roof, +15C. Painting must be OK ;)
Unless very windy.....
Offline BenelliSEI
  • 1969 cb750
« Reply #1045 on: April 13, 2024, 05:33:36 AM »
Per…. 03.0 C here today. May have to wait a little longer.
« Reply #1046 on: April 13, 2024, 05:51:08 AM »
Have over +15C now.
First ride within an hour ;)
Offline BenelliSEI
  • 1969 cb750
« Reply #1047 on: April 13, 2024, 06:19:27 AM »
Have over +15C now.
Watch out for dirty roads and enjoy!
« Reply #1048 on: April 14, 2024, 07:59:39 PM »
That's a real fine tank-holder, B. Very cool!
Offline BenelliSEI
  • 1969 cb750
« Reply #1049 on: April 15, 2024, 05:58:56 AM »
Thanks! I hope the “Paintless dent wizard” approves. He’s been so busy I haven’t had a chance to drop in on him yet!
« Last Edit: May 02, 2024, 06:16:52 PM by BenelliSEI »
