Author Topic: Early Sandcast Found......  (Read 147036 times)
Offline BenelliSEI
  • 1969 cb750
Re: Early Sandcast Found......
« Reply #1500 on: September 17, 2024, 11:30:03 AM »
Congratulations for the fantastic  validation of your CB750 -69!
All that in one day?
Yup. I might go out again later. We are having fantastic weather!
Offline BenelliSEI
  • 1969 cb750
« Reply #1501 on: September 17, 2024, 11:32:30 AM »
John, you may have mentioned earlier, but what are your long term plans for the bike?  Plan on keeping it?
Denis….. No plans. If I get it accurately appraised, the insurance premiums will be high (Ontario has some very rich insurance companies!). Definitely going to enjoy it for now.
« Reply #1502 on: September 18, 2024, 08:07:17 AM »
The Judges were extremely knowledgeable..
I had wondered about that, would they even know what a "Sandcast" was? And when I think of "concours", It is typically perfectly restored vehicles such as the other bikes you were up against.  Once again, congrats!
PS. Was there only 1 class winner for all 12 bikes? Or other categories to win in??
Offline JamesH
« Reply #1503 on: September 18, 2024, 08:08:48 AM »
Amazing work congrats John
Sent from my iPhone using Tapatalk Pro
Offline BenelliSEI
  • 1969 cb750
« Reply #1504 on: September 18, 2024, 07:51:03 PM »
Only one…..
Offline BenelliSEI
  • 1969 cb750
« Reply #1505 on: September 18, 2024, 07:51:59 PM »
Thanks James! Must have been those clamps!
Online grcamna2
« Reply #1506 on: September 18, 2024, 09:03:53 PM »
I like how much they appreciated your excellent work: 1st  :) ;) 8) 8)
75' CB400F/'bunch o' parts'
Offline BenelliSEI
  • 1969 cb750
« Reply #1507 on: September 19, 2024, 05:11:15 AM »
Steve…. Messed that answer up. Only one winner. They create a single class that changes every year. Last year was American and the year before (when I took the Benelli) was Italian. I think next year will be British.
« Last Edit: September 19, 2024, 01:11:38 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #1508 on: September 19, 2024, 10:07:19 AM »
Cobble Beach just sent us this photo. Taken in front of the main Clubhouse, then off to the “Winner’s Circle” for champagne! These fellows really know how to top off a great weekend.
Checkout their website for a truly stunning line up of winning cars.
« Last Edit: September 19, 2024, 01:08:07 PM by BenelliSEI »
Online grcamna2
« Reply #1509 on: September 19, 2024, 12:18:37 PM »
Yeah !
Offline BenelliSEI
  • 1969 cb750
« Reply #1510 on: September 20, 2024, 11:20:15 AM »
Projects are never really done. At the show I realized the side stand was “short” and missed hitting the rubber disc on the lower pipe….. Today I removed it and it’s visibly bent, right up near the bolt end. Set it up on blocks in the press and gave it a “push”. Once straight it lined up perfectly in every direction and the bike sits nicely on it.
Hint…. I discovered a great way to reinstall the spring, a while back (wear safety glasses and gloves for this stunt). Put the side stand in the down position and hook the spring at the frame end. Take a large Phillips screwdriver and line up one of the tip grooves under the hook on the stand. Loop the spring on the shaft of the screwdriver. Using both hands, push straight down on the handle of the screw driver. Everything gets really tight but as soon as the shaft gets below the hook, the spring shoots up the screwdriver shank and snaps into place.
Still to do:
1) repair, polish and install the original pipes.
2) repair and install a faded air box to match the rest of the “bodywork”.
3) oil and filter change.
4. Full Winter prep.
« Last Edit: September 20, 2024, 11:27:51 AM by BenelliSEI »
Offline lash
« Reply #1511 on: September 20, 2024, 01:06:44 PM »
Do you need that box of mine you looked at?
Offline BenelliSEI
  • 1969 cb750
« Reply #1512 on: September 20, 2024, 02:06:14 PM »
Yes….. I should have grabbed it on the day!
Offline lash
« Reply #1513 on: September 20, 2024, 02:34:07 PM »
I’ll let you know when I get back..
Offline BenelliSEI
  • 1969 cb750
« Reply #1514 on: September 20, 2024, 08:33:59 PM »
Thanks!
Offline BenelliSEI
  • 1969 cb750
« Reply #1515 on: September 23, 2024, 07:09:37 AM »
Yesterday looked like the last one of some very fine weather. Put +25 miles on the “Sandcast” and it just seemed to perform better and better! Dumped the oil and filter when hot. Fresh will go in today and not sure after that? Winterize? Maybe not just yet!
« Last Edit: September 23, 2024, 07:13:41 AM by BenelliSEI »
Online grcamna2
« Reply #1516 on: September 23, 2024, 11:40:44 AM »
Early CB750K0 sandcast found,restored and enjoyed !
Glad to hear it's being ridden and you get to 'feel' the result of all that hard work  :)
Offline BenelliSEI
  • 1969 cb750
« Reply #1517 on: September 23, 2024, 08:13:56 PM »
Good day to run it a bit…. The weather has changed here!
Online grcamna2
« Reply #1518 on: September 23, 2024, 09:25:19 PM »
Cool weather for a quick break-in.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #1519 on: September 26, 2024, 02:44:20 PM »
Just wondering, did you re-use the oils hoses?
I don’t remember if I read about them.
Very nice sandy. Keep it alive!
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline BenelliSEI
  • 1969 cb750
« Reply #1520 on: September 30, 2024, 06:09:57 PM »
Steve…. Busy with the race car, missed your question. To answer: Yes (sort of)! The visible, outside line is the original. It cleaned up really well. I polished the ends and washed the hose with a thin mix of black paint and varsol. They are quite unique, very smooth hose and easily spotted by the “experts”.
The back pipe on mine had been previously replaced and I could see why. There was a brutal bit of welding “splash” that must have sliced through the original rubber hose and was 1/2 way through the second one. It was the later style with the braided look. I smoothed up the frame, before paint and replaced the hose with the best used one I had. Not perfect, but almost invisible…..
« Last Edit: September 30, 2024, 06:11:53 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #1521 on: October 04, 2024, 05:28:36 PM »
Both the new 17T sprockets I had put away for this project are too thick. Machined the raised step off one side of one today and it fits and lines up perfectly. The bike came with a fairly worn 16T that I used originally. Thought I was done?
A fellow that saw this motorcycle at Cobble Beach called today. He has a “client” that wants a Sandcast for his collection. I told him to keep looking.
« Last Edit: October 04, 2024, 05:31:53 PM by BenelliSEI »
« Reply #1522 on: October 04, 2024, 11:14:13 PM »
Answer with a very high price ;)
That might keep buyers away ;D
Offline lash
« Reply #1523 on: October 05, 2024, 03:48:45 AM »
Anybody that calls their bikes a “collection” probably doesn’t ride them…
Offline Mikey G.
« Reply #1524 on: October 05, 2024, 12:07:55 PM »
I just looked up where the Cobble Beach show is, and it's surprisingly close to where I'm at.  I'd need to get my passport of course, but that's easy enough to do.  It's definitely worth checking out one day!
-1970 CB750 K0
-1980 KZ1300
-1976 Yellow GL1000
-1965 CA77 "Dream"
-1997 Valkyrie
-1975 Velosolex
