Author Topic: Early Sandcast Found......  (Read 137758 times)
Re: Early Sandcast Found......
« Reply #475 on: December 29, 2021, 12:04:28 PM »
Don, I have never seen any where you actually can draw the d washers tight.  If they are captured, you have way over-torqued.  That is why I never understood what the big deal with these has become.  What was Honda's purpose of installing them?
« Reply #476 on: December 29, 2021, 01:54:57 PM »
I think it wasHonda’s attempt to prevent a ham fisted mechanic of over torquing the pinch bolts leading to cracked triple tree clamps from fatigue from the jolts if they could torque them closed to begin with….
Online Don R
« Reply #477 on: December 29, 2021, 02:55:57 PM »
Agreed. I have several broken ones, a couple done by myself, believing you were supposed to draw them tight.
Online BenelliSEI
  • 1969 cb750
« Reply #478 on: December 29, 2021, 03:03:20 PM »
  My replacement K0 fork tubes seem a bit oversize. Watch out for that when tightening the top triple. I can't draw the D washers up tight.
Don…. I found the same thing last time I used a set! Where did you get yours? I think I went to CycleEx. My originals are not bad, I may reuse them.
« Reply #479 on: December 30, 2021, 01:55:25 AM »
I've actually had a "Rhino" top triple that wasn't busted, but the gap was so tight with no bolt in it that I couldn't fit a D washer in it! ;D
« Reply #480 on: December 30, 2021, 03:46:23 AM »
I had to check my K2 with US rhino. Yes, the D washers sit loose, rattling.
I doubt the fork tubes are too wide. They should be tricky to fit the trees then. I put a screwdriver in each opening open them a little more to ensure no scratches in the chrome when assembled it.
It has tubes from cyclex 2013. I later ordered a set from davidsilver uk that had same wrapping around them. I think it was a Korean company. I see same wrapping from German sellers too.
Can the earlier stock tubes be thinner at the upper part?
I measured old Honda tubes from 1974-75. Same diameter.
That washer must be a stopper for muscular truck mecanics?
The later version has a thinner bolt here, M6, not M8 as the earlier. Probably to stop the guys with 1/2" socket wrenches.
« Last Edit: December 30, 2021, 04:38:01 AM by PeWe »
Offline 69cb750
« Reply #481 on: December 30, 2021, 06:40:37 AM »
The purpose was to protect the clamp, the D washers are to thin.
Two bikes came with D washers and broken clamps.
Online Don R
« Reply #482 on: January 04, 2022, 10:41:29 AM »
   I'm thinking my fork tubes were from 4-1 or one of the other ebay suppliers. Probably china made. Forks by Frank were not shipping back then.
« Reply #483 on: January 04, 2022, 05:01:24 PM »
Is "Forking by Frank" still in operation? I bought some 2" over tubes from them 20 years ago, was very impressed. ;D
Online Don R
« Reply #484 on: January 04, 2022, 05:15:58 PM »
https://www.franksforks.com/  I think the original frank is no longer with us.
« Last Edit: January 04, 2022, 05:17:55 PM by Don R »
Online BenelliSEI
  • 1969 cb750
« Reply #485 on: January 04, 2022, 05:40:02 PM »
Don… thanks for the link! I sent for a quote and will try Franks.
Online BenelliSEI
  • 1969 cb750
« Reply #486 on: January 05, 2022, 07:09:34 AM »
Yesterday I was looking at my fuel tank. It’s a true wrinkle tank, with four clear indents for the carb tops, in the bottom panel. Somewhere here (years ago) I remember reading about wrinkle tanks without the recesses.....
Anyone have more details? Thanks!
Offline 69cb750
« Reply #487 on: January 05, 2022, 08:05:27 AM »
Early sandcast tanks do not have indent
Later sandcast tanks have the indent, the change gave throttle cables more room.
Offline Prospect
« Reply #488 on: January 05, 2022, 03:44:56 PM »
Correct. Also, the early ones had larger capacity by two litres. Apparently there is a 2 dimple tank version as well. So Honda went from no diplme to two dimples to four dimples.
« Last Edit: January 05, 2022, 03:47:34 PM by Prospect »
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Online BenelliSEI
  • 1969 cb750
« Reply #489 on: January 06, 2022, 06:24:24 AM »
Interesting...... mines’s pretty early, #1250. It clearly has the 4 dimples.
Offline atm cycles
« Reply #490 on: January 06, 2022, 04:45:56 PM »
What’s the date code? Yours should be double wrinkle tank like the red one
Online BenelliSEI
  • 1969 cb750
« Reply #491 on: January 06, 2022, 05:47:15 PM »
It’s too early for a VIN plate or date code. Tank looks identical to the red one. I’ll take a picture next time.
Offline atm cycles
« Reply #492 on: January 06, 2022, 05:56:19 PM »
Date code on the tank
Online BenelliSEI
  • 1969 cb750
« Reply #493 on: January 06, 2022, 06:02:38 PM »
Offline atm cycles
« Reply #494 on: January 06, 2022, 06:03:52 PM »
I’m trying. Says file too large
Offline atm cycles
« Reply #495 on: January 06, 2022, 06:08:11 PM »
Underside. Where rear rubber holder is
Offline Prospect
« Reply #496 on: January 06, 2022, 06:10:18 PM »
The date code is underneath by where the rubber absorber attaches. Near the side closer to the seat. Where you see all those little indentations.
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
Offline Prospect
« Reply #497 on: January 06, 2022, 06:16:00 PM »
Usually starts with a 4 followed by some other numbers which relate to the anniversary of the swearing in of the Japanese emperor.
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
Offline atm cycles
« Reply #498 on: January 07, 2022, 01:19:24 PM »
4 3 then something between 1-31 ?
Online BenelliSEI
  • 1969 cb750
« Reply #499 on: January 07, 2022, 04:37:45 PM »
Looked today, but may have missed them. Definitely “double wrinkle”.....
