Author Topic: Early Sandcast Found......  (Read 89402 times)
0 Members and 22 Guests are viewing this topic.
Online BenelliSEI
  • 1969 cb750
Re: Early Sandcast Found......
« Reply #775 on: November 12, 2022, 01:43:20 pm »
Please advise which kind of gaskets you plan to use?
I’ll probably need another Yamiya order, so thinking of trying their’s? I do have 1/2 a dozen open gaskets sets, so may just poke through those. What do you guys recommend?
Offline 71 V12
« Reply #776 on: November 13, 2022, 03:31:23 pm »
Personally, genuine Honda only especially on 682!
Online BenelliSEI
  • 1969 cb750
« Reply #777 on: November 13, 2022, 04:49:59 pm »
Good point. Last time I ordered one from Honda Canada it looked +40 years old and had been poorly treated. May try again.....
« Reply #778 on: November 13, 2022, 09:40:20 pm »
The sandcast forum might have recommendations about gaskets for a sandcast engine.
Yamiya's kit was good when I used it some years ago.
Blue gaskets with all holes correct like Hondas light green.
I think the head gasket was as  most other newer, 1mm thick and in need of the thicker o-rings Hondaman reminds us about.
Offline Prospect
« Reply #779 on: November 21, 2022, 06:25:20 am »
I used Athena gaskets on my k1. Seems to be ok.
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #780 on: November 21, 2022, 06:45:21 am »
Have to get those barrels off!
1973 CB 750 K3
10/72 build Z1 Kawasaki
Online BenelliSEI
  • 1969 cb750
« Reply #781 on: November 21, 2022, 07:24:32 am »
No joy last attempt. Going to build a lifting bar next and suspend it for a few days!
« Reply #782 on: November 21, 2022, 08:45:14 pm »
 DaNG, a lucky caps lock accident. Sorry to hear they are still hanging on.
Online BenelliSEI
  • 1969 cb750
« Reply #783 on: November 24, 2022, 03:28:41 pm »
It’s been “hanging” for a few days. Sent lots of juice down the std holes, and been tapping away. Truthfully, more than tapping......Nothing has budged!
« Reply #784 on: November 24, 2022, 03:42:59 pm »
Talk to an appliance repair shop...tell them of your plight and ask if they have an old beater oven they could sell you or give you for purpose of baking this block and cylinders to get them to separate. Turn it into a powdercoat oven after you finish with it for this purpose.
Baking at 450-500 might get it to free up with a few good smacks...
Just be careful you don't lose or drop a liner out of the cylinders...
Online BenelliSEI
  • 1969 cb750
« Reply #785 on: November 24, 2022, 04:43:26 pm »
Mmmmm ..... Heating the entire lump would make the expansion of both parts equal? Was thinking of heating from below (propane BBQ) while cooling the barrel with a fan?). Crazy thoughts?
« Reply #786 on: November 24, 2022, 05:26:57 pm »
 I tried a maap hand torch and a hot air gun on cylinders to remove pistons, not much luck getting things hot.  I was ready to try a rosebud tip on oxy-acetylene. Used my press instead, I put a load on each piston one at a time and went in the house.
Online BenelliSEI
  • 1969 cb750
« Reply #787 on: November 24, 2022, 06:29:53 pm »
Don..... Pistons are free, bores look good, and it had an excellent leak down. I may just leave the damn thing where it is!
« Reply #788 on: November 25, 2022, 01:05:36 am »
It may not be the expansion that breaks things free but the heat cycles. The pins if stuck are not of aluminum but made of steel, so their expansion won't be the same until the temps stabilize. So bake it and a few smacks while it is hot can get things to move.
Online BenelliSEI
  • 1969 cb750
« Reply #789 on: November 25, 2022, 05:47:25 am »
Very good point! Don’s suggested another good “pulling” tactic, so will combine the two if needed.
Thanks, both of you!
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #790 on: November 25, 2022, 01:57:22 pm »
I think a heat gun will be safer than any form of torch, better heat spread and lower temperature.
It will eventually break loose.
1973 CB 750 K3
Online BenelliSEI
  • 1969 cb750
« Reply #791 on: December 01, 2022, 12:58:58 pm »
Built the “Puller” and used a heat gun on the front studs, each end. Really warmed up the area of the two dowel sleeves and it finally popped.
Online BenelliSEI
  • 1969 cb750
« Reply #792 on: December 01, 2022, 01:00:23 pm »
Stripped down the head today, ready to try hydro blasting.
Offline newday777
« Reply #793 on: December 01, 2022, 01:57:08 pm »
Clean off all the oils before you hydro blast or the slurry will be contaminated with oil/grease. Less cutting force.
Stu
My current rides
Prior bikes....
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #794 on: December 01, 2022, 02:39:01 pm »
Very clever puller.
It’s really great you are saving another sandcast.
1973 CB 750 K3
Online BenelliSEI
  • 1969 cb750
« Reply #795 on: December 01, 2022, 04:32:42 pm »
Will do.
Online BenelliSEI
  • 1969 cb750
« Reply #796 on: December 01, 2022, 04:33:57 pm »
Very clever puller.
Even with a lot of “pre load” and heat, it took a lot of heat and a FBH!
Online BenelliSEI
  • 1969 cb750
« Reply #797 on: December 07, 2022, 08:04:46 pm »
Top end is stripped and off for vapour blasting. When it returns, I’ll be tackling “fin straightening”.
Online BenelliSEI
  • 1969 cb750
« Reply #798 on: December 07, 2022, 08:09:37 pm »
I had a good look at the original pipes today. Both side lowers have holes where the “muffler” portion joins the headpipe. The two uppers are in much better shape. None of them have any real dings or dents, so will try and patch and polish these up. I do have a new, still in the boxes, set of Yamiya no# pipes too.
« Reply #799 on: December 08, 2022, 02:35:13 am »
You really ought to consider straightening and any welding in those before blasting, that way you can have a consistent finish on them as any welds and grinding will be subjected to the same texturing the vapor honing does.
But, depending upon your paint finish thickness it might be a mute point.
