Author Topic: Early Sandcast Found......  (Read 89409 times)
0 Members and 25 Guests are viewing this topic.
Online BenelliSEI
  • 1969 cb750
Re: Early Sandcast Found......
« Reply #800 on: December 08, 2022, 05:12:14 am »
I may just take a run at them before the cleaning.
Online BenelliSEI
  • 1969 cb750
« Reply #801 on: December 15, 2022, 09:14:31 am »
Dropped the two main parts (barrels and head) at Rocket Performance, Whitby, Ont., for vapour blasting. Examined other stuff he’s done. Amazing results. He’s busy, so may be the New Year, before they are done. I’ll do pistons and rings in the meantime, clean valve train and general prep. Not in any rush....
His results looked so great, I may dismantle the carbs again, and get him to do the main bodies, tops and float bowls. I got them very clean in my ultra sonic tank, but they still show “staining”. We’ll see.
« Last Edit: January 16, 2023, 09:25:23 am by BenelliSEI »
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #802 on: December 15, 2022, 01:55:11 pm »
If there is any rust showing on the outside of the pipes I bet the amount on the inside is much greater. Sad to say.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #803 on: December 15, 2022, 02:08:04 pm »
I may dismantle the cars again, and get him to do the main bodies, tops and float bowls. I got them very clean in my ultra sonic tank, but they still show “staining”. We’ll see.
Hey John...I had my H2 carbs vapor blasted a few years ago and they still look great.  IMO, it is by far the best finish you can apply to aluminum...
« Reply #804 on: December 15, 2022, 07:36:45 pm »
I agree.  I had mine vapor blasted and then had matte black cerakote applied to the bodies for some contrast to the engine.
IMG_0116 by Donald Leonhardt, on Flickr
« Last Edit: December 16, 2022, 08:53:29 am by SOHC4 Cafe Racer Fan »
Online BenelliSEI
  • 1969 cb750
« Reply #805 on: December 16, 2022, 06:26:27 am »
??????  What pipes?
Online BenelliSEI
  • 1969 cb750
« Reply #806 on: December 16, 2022, 06:27:41 am »
Wow..... will definitely take mine apar, while waiting. That looks even better than I expected.
« Reply #807 on: December 16, 2022, 08:52:45 am »
Here are my carbs after vapor blasting, and then after applying cerakote and assembly.  The peened finish after blasting retains its finish.  I wanted mine impervious to gas, so I had them cerakoted.
[Those aren't my hands.]
Untitled by Donald Leonhardt, on Flickr
« Last Edit: December 16, 2022, 08:55:28 am by SOHC4 Cafe Racer Fan »
« Reply #808 on: December 16, 2022, 11:05:48 am »
Funny you should state that Don, was thinking you've been working with your hands too much!
Your carbs look great, can you plz explain the Cerakote process?  Thx
« Reply #809 on: December 16, 2022, 01:21:58 pm »
Cerakote is a ceramic coating applied with a paint gun.  It requires slightly more prep than paint and air cures.  Once cured, it extremely durable/scratch resistant and nearly stain proof (especially as to gas/oil/petroleum products). There are numerous colors available.  It has great heat dispersion qualities so it's safe on engines and exhaust components. It cures to very thin thicknesses, so not much is needed. It is used for guns as well (including slides which endure heat and friction).
Online BenelliSEI
  • 1969 cb750
« Reply #810 on: December 16, 2022, 04:30:45 pm »
Don..... thanks for the details! I will investigate. How hard is the gun cleanup afterwards?
« Reply #811 on: December 19, 2022, 08:16:55 am »
I have not shot it myself.  My buddy does it.  He says that clean up is similar to paint but you have to be thorough.
Online BenelliSEI
  • 1969 cb750
« Reply #812 on: December 31, 2022, 06:08:07 am »
Last post for 2022. Received a nice note via “snail mail” from Mark P. today. It included the correct head gasket “0” rings I will need for this project. Very generous and many thanks, Mark!
Happy New Year all!
Online BenelliSEI
  • 1969 cb750
« Reply #813 on: January 11, 2023, 05:27:45 pm »
Stripped the chrome, cap and badges off the s/c tank today and took it to a paintless dent remover that has an excellent reputation. It has a few dents, but no cracks in the paint. If he can “save” it, I want to polish it up and leave truly original. Fingers crossed!
« Reply #814 on: January 11, 2023, 08:39:28 pm »
That look what a dent(ist) can fix without fillings.
Original must increase value, right?
Tank has a story to tell, what did it see 1969?
Online BenelliSEI
  • 1969 cb750
« Reply #815 on: January 12, 2023, 06:16:17 am »
PeWe..... apparently it’s a very early “17 litre, double wrinkle tank” . Built in May of 1969.
« Reply #816 on: January 12, 2023, 08:01:33 am »
A good detail for initiated collectors.
Double value then! ;)
Online BenelliSEI
  • 1969 cb750
« Reply #817 on: January 12, 2023, 09:29:29 am »
Most importantly it’s original to the motorcycle. Only the carbs, airbox and some switches were missing (day 1 photo attached). I’m trying to restore, rebuild, reuse as much as possible.
Waiting for a clean cylinder head from vapour blasting. Cleaned up all the valves today.....
« Last Edit: January 13, 2023, 05:23:04 am by BenelliSEI »
« Reply #818 on: January 13, 2023, 01:21:04 am »
I'll be interested to see how the PDR works John. The tank on my K0 is off an early K1, but as Mark Paris has mentioned previously, K1and later tanks don't fit K0's well, so I want to have the tank on my K2 "Bitsa" which is an original K0 tank repaired (I'll have it repainted as the paint is pretty bad) and put on my K0, and put the tank that's on my K0, on a future K1 build. ;D
K2 Bitsa Thursday 5 Jan 2023 2 by Terry Prendergast, on Flickr
Online BenelliSEI
  • 1969 cb750
« Reply #819 on: January 13, 2023, 05:20:11 am »
Understood.... This “wrinkle tank” is the only one I have with the extra room for the 4-1 cables, where the adjusters come out of the carb tops. My 1970 K0 had a brand new, factory Honda K1 tank with out those cut outs and it never sat down quite correctly...
« Last Edit: January 13, 2023, 11:35:14 am by BenelliSEI »
Online BenelliSEI
  • 1969 cb750
« Reply #820 on: January 13, 2023, 01:19:30 pm »
Keeping valves and springs organized.
Online BenelliSEI
  • 1969 cb750
« Reply #821 on: January 13, 2023, 01:20:56 pm »
Valve cleanup station. 3M Green Scotchbrite, varsol, and the plastic tube protects the valve stem in the drill press chuck.
« Last Edit: January 14, 2023, 06:08:26 pm by BenelliSEI »
« Reply #822 on: January 14, 2023, 12:06:21 am »
Yep, I think it was Frank who said that there were at least 3 (maybe 4?) K0 tanks, the first ones didn't have those "dents" for the the carb tops, then the next ones had just two dents, then the last wrinkle tanks had 4. Mine is a January 1970 K0 so didn't have a wrinkle tank, so I sold the "4 dent" wrinkle tank that I'd bought for it. If I can get my 1970 "Non Wrinkle" tank repaired so it looks like new, I'll put it on my K0 and free up that K1 tank for my K1 build, when I get around to it. ;D
Offline newday777
« Reply #823 on: January 14, 2023, 04:17:54 am »
I forgot about doing this from years ago and I like the cleanup station too. Thanks 😊
Stu
My current rides
Prior bikes....
Online BenelliSEI
  • 1969 cb750
« Reply #824 on: January 14, 2023, 06:21:39 am »
It’s “old school”, but works well. The 2X4 for the LEXUS race car is 2’ long (24 valves)!
