Author Topic: Early Sandcast Found......  (Read 89226 times)
0 Members and 12 Guests are viewing this topic.
Offline BenelliSEI
  • 1969 cb750
Re: Early Sandcast Found......
« Reply #850 on: January 28, 2023, 05:47:36 am »
Vapor blasting looks to be top shelf work! That fellow’s shop sounds like a place that would be fantastic to hang out and watch the fellow work if he didn’t mind your presence. The old ways and skills of a lot of old machinists and other craftsmen is fascinating to watch… sometimes you see the logic in their steps and learn new ways to approach things. Often these guys apprenticed with guys and you see generations of knowledge in action. When I was starting out in product engineering after college I got to hang out with a few machinists and a facilities maintenance guy and I enjoyed learning from the old guard. It opened my eyes to different solutions and the one machinist did maintenance and refurbishment and periodic rebuilds on some of our equipment that was probably 75 years old then, mid 80s.
Lost artisan ways…
David.... this guy is really fascinating. Built his first Chopper when he was 16, in his parent’s basement. Next one (he still has it) used a GL1000 drive train. Two small radiators under the side cover (scoops like on a jet aircraft), including small fans under the seat! Ceiling of the shop is filled with radio controllerd aircraft that he builds too! Next time, I will take photos.
« Last Edit: July 05, 2023, 07:03:07 pm by BenelliSEI »
Online denward17
« Reply #851 on: January 28, 2023, 05:56:44 am »
It’s pouring here today but all is well.
That shop sounds great.
Your weather goes down the Drains! Photos of head. Spotless.....
That head looks great, do you plan to paint?
Offline BenelliSEI
  • 1969 cb750
« Reply #852 on: January 28, 2023, 06:28:29 am »
Yes..... originally they had a light coat. Will do the same. I use the Duplicolor 1615 engine paint. Very close to original....
Online denward17
« Reply #853 on: January 28, 2023, 06:57:24 am »
^^^ Beautiful...
« Reply #854 on: January 28, 2023, 07:10:28 am »
Vapor blasting is the absolute best way to "refinish" aluminum, I have done at least two motors plus numerous parts. I painted the Honda motor but let the Kawasaki H2 motor "naked" as that is the way it came from the factory in '74. I sent the motor [case, 3 cylinders and 3 heads] to member Nils in AZ and he did a great job for a reasonable price [sadly, he has since closed his shop down].  After 3+ years, the motor still looks great.
Offline BenelliSEI
  • 1969 cb750
« Reply #855 on: January 28, 2023, 07:20:42 am »
Thanks, the K0 is gone now, but hope the S/C will look as good
Steve..... that bare top end looks great! My cases need paint, so I’ll have to “dust” the top to match.
« Reply #856 on: January 28, 2023, 07:24:12 am »
Thanks John.  I would do the same, paint the entire engine.  Did you ask about prep before paint? Sometimes VB can leave a light residue.  I dont recall what I did on my Honda motor that I painted, maybe nothing?
Offline BenelliSEI
  • 1969 cb750
« Reply #857 on: January 28, 2023, 07:29:41 am »
I think after I lap the valves in, I’m going to put a storage tote in the bath tub and give it a hot water and lots of dishwashing liquid “bath” with a really good scrub. Can’t hurt....
Offline BenelliSEI
  • 1969 cb750
« Reply #858 on: February 03, 2023, 08:17:40 am »
Tried lapping in valves this morning. Shop was too “cool” and the suction cup just wouldn’t stick to the  valve faces!! Outside temp is -21 degrees Celsius. Heating up the parts, bench, and shop. Will try again later...... Frostbite weather.
Offline Shtonecb500
    • Youtube profile
« Reply #859 on: February 03, 2023, 09:01:16 am »
2 weeks of cold in Detroit have me looking for second hand kerosene heaters for the garage so i can accomplish something.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Online PeWe
« Reply #860 on: February 03, 2023, 10:42:01 am »
Bring it into the kitchen ;)
Your head is cleaner than a frying pan ;D
Offline BenelliSEI
  • 1969 cb750
« Reply #861 on: February 03, 2023, 11:45:32 am »
When down there this aft and just gave up. It was even cooler. Suppose to warm up a bit by Sunday...
Offline BenelliSEI
  • 1969 cb750
« Reply #862 on: February 06, 2023, 12:43:30 pm »
Very lightly lapped in the valves to #1 today. Screwed in a plug, flipped it over and filled the chamber with clean varsol. Went back in 10 minutes, not a drop of seep. Also checked and cleared every tapped hole in the head.
Despite the claims of the Vapour Blasting Shop, there was a bit of crap in the bottom of every blind hole. Blew them all out, but also checked to see if the head fits in my “new to me” ultra sonic tank. I’m going to strip those valves out again, and lay the head up side down in the tank basket for an hour “buzz”. I want this thing spotless.
Online denward17
« Reply #863 on: February 06, 2023, 01:07:22 pm »
Nice!
That head is going to be so clean......
Offline BenelliSEI
  • 1969 cb750
« Reply #864 on: February 07, 2023, 06:23:13 pm »
Nice!
Did it today and it worked well! Finish lapping valves and assemble head tomorrow.
Online PeWe
« Reply #865 on: February 07, 2023, 08:59:52 pm »
Much blasting media in the tank?
Offline BenelliSEI
  • 1969 cb750
« Reply #866 on: February 08, 2023, 06:16:38 am »
Per..... not really. I think what was stuck in all the threaded holes was old dirt that got “packed” in by the vapour blasting. I dug around in each spot with a long, sharp point, turned it upside down in the tank, and all came clean.
Offline BenelliSEI
  • 1969 cb750
« Reply #867 on: February 08, 2023, 12:55:57 pm »
Finished up valves, all back in the super clean head!
Waiting for “fin repairs” on the barrels, lots of other stuff to do before top end build.
« Last Edit: February 08, 2023, 12:59:25 pm by BenelliSEI »
Online denward17
« Reply #868 on: February 08, 2023, 01:11:17 pm »
^Looks nice.....
Offline BenelliSEI
  • 1969 cb750
« Reply #869 on: February 08, 2023, 01:13:54 pm »
^Looks nice.....
Thanks. Turned out OK.
Offline BenelliSEI
  • 1969 cb750
« Reply #870 on: February 15, 2023, 09:56:29 am »
Fin repairs to damaged (they were cracked and bent) barrel tuned out absolutely perfect. See before and after photos. Guy I went to is a serious craftsman, did a very light hone as well.  I am delighted.
Online PeWe
« Reply #871 on: February 15, 2023, 09:59:27 am »
How did he fix it?
Just bent it straight or weld needed?
It is not visible.
Offline BenelliSEI
  • 1969 cb750
« Reply #872 on: February 15, 2023, 10:15:10 am »
All the bottom ones were bent and cracked at the base, inside. Took them all off, straightened, welded, built up, ground and shaped. A few, with small dings, he built up with weld, and reshaped. Finally, with several small air tools he built for refinishing old Indian blocks and heads, he finished the surfaces to perfection...... Very impressive, invisible repair.
Online PeWe
« Reply #873 on: February 15, 2023, 11:23:24 am »
A real craftsman!
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #874 on: February 15, 2023, 01:58:41 pm »
It’s looking really good.
I had a bin with about 50% Simple Green and water, it did a great job on most parts if I gave it some time.
1973 CB 750 K3
10/72 build Z1 Kawasaki
